Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
93 LT1 MSD question
Old Jun 14, 2020 | 11:04 AM
93BlackTA's Avatar
93 LT1 MSD question
I have installed a couple MSD 6AL boxes over the years that take the RPM rev limiter pills...I just installed a msd 6425 ignition box with adjustable rev limit on a 93 Trans Am, the car ran great before the install, i used the msd harness so i didnt have to cut the coil harness..the car fires up perfectly but will not hit the desired Rev Limit..It doesn't matter what the setting is at it will only hit about 5500 RPM....so i decided to unhook the 6AL and hook it back up like factory and now the car will not start when its hooked up like stock....if i hook up the MSD 6AL box it fires right up but still will not hit the rev limiter...is there an issue with the new 6425 box that will not allow it to hit the limiter but will allow it to start.....AND why will the car not start when the MSD 6425 is unhooked and returned to stock setup.
Old Nov 9, 2023 | 09:07 PM
Gtpguy's Avatar
Re: 93 LT1 MSD question
Ever figure this out? I take it your car had the stock tune/rev limiter?
Old Nov 9, 2023 | 10:05 PM
He signed off 15 minutes after posting above, and never signed in again.
henryz28
Nov 26, 2010 09:08 AM
williamfvc
Mar 1, 2008 07:53 AM
Cutlass425f85
Jan 19, 2005 06:43 PM
TransAm396
Jan 17, 2005 03:30 PM
Victory Racing
Jul 21, 2004 02:52 AM
