Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
26.8lb injectors to 28.8lb ???
Old Dec 5, 2007 | 12:19 PM
00ls100's Avatar
k, so I'm going to be doing an ls6 intake install on my car and was wondering if it would be beneficial to "upgrade" to 28# injectors?
seeing that my car ( 2000 TA) came with 26# injectors. I have all the mods in my sig + an ls6 intake to be installed, ported TB to be installed + a 40% chanceof doing a cam (maybe heads too) in the future.
Without the heads/cam will the stock 26# max out or am I fine??
Old Dec 5, 2007 | 01:23 PM
soul strife's Avatar
You will be fine right now. With a heads/cam package, the injector depends on how big the cam and how much the heads flow. So, you will want to match that up with the injector.
Old Dec 6, 2007 | 04:11 AM
rskrause's Avatar
Moderator
They will be fine, but there is not much "reserve" and if you do a cam you may need larger injectors. It would amost never make sense to go from 26 to 28# though. 28# injectors can support ~25 hp more than 26#'ers.
Rich
Old Dec 6, 2007 | 10:00 AM
00ls100's Avatar
ok I'll stick with the stockers thanks for the replies
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
