Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
255lph pump install question
Old Feb 12, 2007 | 05:17 AM
blue 79 Z/28's Avatar
i got a walbro 255lph pump its for my LT1 project, only thing is, the car is still a 3.8L buick right now. i just finished building the diff and putting a modded disk brake rear together. i need to install it to i can finish the rear suspension, and since it all has to come out i was going to put the fuel pump in. i was just wondering if theres any reason not to? i know the v6 runs the same fuel pressure, the added flow shouldnt be an issue should it? just in the meantime till i get the LT1 in.
Old Feb 13, 2007 | 01:33 AM
nobody?
Old Feb 13, 2007 | 10:04 AM
seawolf06's Avatar
I can't see why that would make any difference. It's not going to flow more than you need.
Old Feb 13, 2007 | 10:19 AM
Soccerbum21's Avatar
you're fuel pressure regulator will keep the pressure in check. it wont flow more unless the engine demands more. aka, with 8 injectors it would take more flow to keep 43.5 psi fuel pressure in the rails as opposed to the 6 tiny injectors on the 3.8
sooooo...no problem putting it in now
Deadbolt24
Jan 19, 2015 01:29 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
