Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
22 lb fuel injectors
Old Jan 16, 2015 | 09:12 PM
94Z28LS1toLT1's Avatar
Found a guy selling LT1 parts and was wondering if 22lb injectors would be ok my LT1
Old Jan 16, 2015 | 10:59 PM
blac94Z's Avatar
Re: 22 lb fuel injectors
I think the stocks are 24lb if I'm not mistaking
Old Jan 17, 2015 | 08:52 AM
93 LT1 is 22 #/HR. 94-97 are 24 #/Hr. If you install the 22's in a 94, the PCM should be reprogrammed for the new size.
If you don't program the PCM, it will try and adjust the long term fuel corrections to correct for the fuel shortfall caused by the "too small" injectors, but that becomes a bit hit-or-miss, depending on whether the long term fuel corrections are already elevated for some other reason.
I woudn't recommend using the 22's unless you have the PCM reprogrammed.
Old Jan 17, 2015 | 08:22 PM
thank you,i see your profile pic if your a colts fan...i hope you guys beat the pats tommorow
thank you buddy im glad i asked you guys 1st before buying them.
Old Jan 17, 2015 | 08:29 PM
blac94Z's Avatar
thanks man I hope we do to it will be great for the colts and Andrew luck
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
