Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
2002 Camaro keeps dying.
Old Jul 10, 2016 | 10:01 PM
Killr68's Avatar
Car runs for about 10 seconds and then just dies. Changed MAF sensor , ignition control module , crank position sensor , checked fuel pressure. With key on , it goes to 50 psi then drops to 42. Start car and fluctuates between 40 and 42 for about 10 seconds , when car dies the gauge goes to 50 and dies. Any ideas ?
Old Jul 11, 2016 | 10:40 AM
Re: 2002 Camaro keeps dying.
Given the description of the parts you replaced, this appears to be a 3.8L V6, and not the LS1 V8. Is that correct? You need to provide basic info about the car. Is the engine stock or modified? How many miles on the car?
Have you scanned it for codes? Any indication of problems with the electronic throttle actuation system?
How long has it been having this problem? Were any changes made just before the problem started? Is the fuel in the tank fresh? How old are the O2 sensors?
Old Jul 11, 2016 | 11:36 AM
Killr68's Avatar
2002 3.8 v6. 98,000 miles. All stock and original. No mods prior to this happening. It has about a half a tank of fuel bought a month ago. Here are codes that were scanned while it was still drive able.
Current
U1016. Loss of communication w/ pcm
P0420. Catalyst system efficiency
P0440. Evap emission system bank 1
P0442. Evan emission system leak (small)
Intermittent
P0300. Random Multiple misfire detected
History
U1000. Class 2 data link malfunction
P0102. Mass air flow curcuit low input.
P0560. System voltage malfunction.
This is my sons car and he said the gauges would stop reading and come back on about a month ago. Then it was harder to start and run a little rough at start up. Then this happened to him after driving for about 15 minutes. Any input is greatly appreciated ! THANKS.
Old Jul 11, 2016 | 09:06 PM
GaryDoug's Avatar
Prominent Member
Sounds like a low voltage problem. What scantool was used to get the U1016 code? What module was being scanned? That indicates that a module was unable to talk to the pcm.
You may have a bad battery or ground cable.
Or it could be a shorting alternator. Try disconnecting the large cable from the alternator and trying again.
chevyowner02
Aug 8, 2015 01:38 PM
Critter
Jul 13, 2015 05:51 PM
rick350
May 5, 2015 05:03 PM
Noenav
Apr 30, 2015 01:06 PM
