1993 Z28 will only run if pumping gas pedal
I have a 1993 Z28 all stock. The car will start and fire but the only way to keep it running is to pump the gas pedal rapidly. If you try to idle at any RPM dies like its starving or loading fuel. Check psi and it is within specs and checked vac lines all ok now. The car sat for about 8 months so I removed the tank and dumped all 14 gallons of gas which was painful with the price of that stuff now and changed the strainer. I also changed the TPS and IAC. ANY IDEAS WOULD BE HELPFUL. Thanks a lot
teedoff59
Aug 8, 2002 01:36 AM
CobraEatr
Jul 29, 2002 11:46 AM
CobraEatr
Jul 23, 2002 06:32 PM
CobraEatr
Jul 22, 2002 09:49 AM
