Will JB Weld hold my Vortech oil drain fitting properly???
Old Feb 8, 2003 | 09:03 PM
96 WS6's Avatar
What I did was screw the fitting in until you could only see 4 or 5 threads. Then I put JB Weld on those threads and tightened it down all the way. I think it may have started to strip but it's in there nice a tight. Then I put a beads of JB Weld all around the fitting and sealed it. I left a portable heater under the car to help it dry overnight. Will I have problems or will this seal it nicely??? JB Weld seems to work good unless its under high pressure or lots of drastic temp. changes. I just want to know if I did this thing right...
Old Feb 8, 2003 | 10:49 PM
Brandy's Avatar
Thats how I did mine for the turbo, seems to work fine so far.
Old Feb 9, 2003 | 08:46 PM
yellow Z28's Avatar
same thing here works great, no problems
Old Feb 9, 2003 | 08:55 PM
sleeperz28's Avatar
it will eventually crack, JB weld is junk!
Old Feb 9, 2003 | 09:03 PM
BigDaddy's Avatar
I've had JB Weld on my radiator for 5 years, and it hasn't leaked yet. A friend's dad used it to seal up holes in his cylinder head, and got another 100k out of it.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Sandersen511
Jan 13, 2015 03:49 PM
squarehead
Nov 21, 2014 08:02 PM
