Will i be able to run pump gas?
Old Feb 23, 2010 | 07:22 PM
mrl510's Avatar
I am building a lt1 procharged 383. The way i figured it out im going to have 8.78:1 compression ratio. If i run 10-12 psi boost will i still be able to run 93 pump gas? I thought i was gonna be able to, but according to summit it will be a race gas motor.
Old Feb 23, 2010 | 11:32 PM
jsetzer's Avatar
Heads cam? What power goals. 12psi might be 400hp or might be 800 depending on the combo.
I was around the same compression and was running 18psi on 91 10% ethanol horse ****. It was a tiny setup and was around 600hp. No issues on pump. People are making 800+ on pump.
Old Feb 24, 2010 | 09:47 AM
koolaid_kid's Avatar
Not sure whether horses urinate in Sunoco 93 in Indiana, but I run it with 14 pounds of boost with no problems at all. Personally, although Summit has good prices, I would never trust them for technical advice. They only care about moving product, nothing else.
Old Feb 24, 2010 | 10:07 AM
jsetzer's Avatar
The few times I have talked to summit they were very helpful, but seemed to still be living in the 60s. They act like you need 8:1 compression to run pump gas with no boost.
Modern fuel injection and tools have come a long way.
Summit, my other parts vendor, and my builder all told me I couldn't do 12:1 on pump gas with my first motor.
Old Feb 24, 2010 | 10:47 PM
dookie454's Avatar
Unfortunately, Summit's opinion is probably one individuals opinion.
My opinion of 14psi with 8.8:1 compression and some ported advancedinduction ported stock heads will give you around 700hp on 92 octane gas.
Im running around 600-650hp at the flywheel with 7-8psi on 92 octane no problems.
Old Feb 25, 2010 | 01:07 AM
Intimidator1997's Avatar
I think you'll be fine. I run 14lbs on an 8.0-1 motor with 91 octane...no detonation. Just get it dyno tuned so you'll know for sure.
Old Feb 25, 2010 | 05:26 PM
jay_rich's Avatar
I ran 8psi on 91 octane on my 383 at 9.8ish:1 ran great pulled hard, made 583rwhp with an exhaust leak, also through a TH400
Jay
Old Mar 10, 2010 | 08:57 AM
fabgmc4me's Avatar
You can do amazing things on pump gas these days. It is all in the tune.
I run about 18lbs-19lbs on my forged 383 using 93oct pump gas. I have a front mount intercooler.
I make just over 600RWHP on a Mustang dyno through a unlocked TH400 and a 9" rear.
Old Mar 18, 2010 | 10:48 PM
4SFEDZ's Avatar
ya no prob. i made 670 thru an unlocked th400, big stall, S60, with a 385 8.5 14psi with 93 octane.
Old Apr 7, 2010 | 11:41 PM
hulettsz28's Avatar
You should be fine. Add some booster if you have six bucks to burn
Old Apr 8, 2010 | 07:39 AM
rskrause's Avatar
Moderator
What pistons are in it?
The tune will be important.
Water injection is a big help in making it live.
Rich
Old Apr 19, 2010 | 06:38 PM
mark97ta's Avatar
my trans am made 800 hp on pump gas with 8.8 cpr and 15 psi, no knock
Deadbolt24
Jan 19, 2015 01:29 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
blac94Z
Nov 24, 2014 07:12 PM
dmaastr
9
Jul 1, 2002 02:22 PM
