Who's going over 135mph trap speeds
Old Jan 9, 2004 | 10:04 AM
Pro Stock John's Avatar
Please post your raceweight and FI setup, and gearing if you could...heck why not post the slick size too LOL.
Old Jan 9, 2004 | 11:41 AM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
11.2 @ 136 2.0 60ft 3,800lbs 315 35 17's. (17's all the way around)
10.9 @ 138.5 1.9 60ft 3,720lbs , 15in frontrunners, 26x11.5 17 et streets
MPH was limited by gearing/rpm. At the time, the car was peaking at around 5,500, and going throught the traps at 6,300. Pulled more mph with the Et streets because they are slightly taller.
Old Jan 9, 2004 | 11:55 AM
rskrause's Avatar
Moderator
Re: Who's going over 135mph trap speeds
4,100lbs car+driver
Procharger F1+70hp nitrous shot
3.42's TH400
27x11.5x15 QTP
10.22 @ 140.4mph
Rich Krause
Old Jan 9, 2004 | 12:08 PM
IDOXLR8's Avatar
Re: Re: Who's going over 135mph trap speeds
Originally posted by rskrause
4,100lbs car+driver
3.42's TH400
27x11.5x15 QTP
10.22 @ 140.4mph
Rich Krause
How do you like the QTP tires? Also did you have to modify the wheel well to get the tires to fit. Thanks. What kind of 60's are you pulling?
Old Jan 9, 2004 | 12:34 PM
MEAN LT1's Avatar
4,100lbs car+driver
Rich Krause
Geez!.........Tell your car to lay off the KFC, she needs to go on a diet!
Old Jan 9, 2004 | 01:35 PM
rskrause's Avatar
Moderator
Re: Re: Re: Who's going over 135mph trap speeds
I like 'em. I went with a 27" tire partially because they fit without any problem. I did trim the inner lip of the bumper cover at the back of the wheel well, but that probably wan't absolutely necessary. The car has a stiff suspension (ie not set up for the drags) and pulls low 1.5's.
Rich Krause
ZZed
Sep 10, 2002 04:13 PM
jp2002ls1
Aug 30, 2002 08:18 PM
z28kid93
Aug 22, 2002 04:40 PM
Notford95
Aug 20, 2002 01:46 AM
96z
Aug 2, 2002 09:00 PM
