What's the fastest 8# car is the country worth?
Re: What's the fastest 8# car is the country worth?
Originally Posted by EDS Z28
I have only a 355 and am running the comp cams 224/236 blower grind, 525/555 lift on 114 lsa. This cam kicks *** as far as I'm concerned. It would be good in a 383 too. Supposedly it passes and I am pretty confident it will, won't know for sure until middle of '06 when it needs to be smogged again. I did pass easily with the hotcam.
Originally Posted by gearhead3
Hello SCZ28, I would like more info on your combo if you dont mind sharing. I am also in CA and I am putting my wifes 383 together with the same procharger. I want to keep it smog legal so cam selection is key. You did not mention the lift.
He did decide to go to a C5, the car went up for sale, on here, I am sure if you looked you can find the thread if you look hard enough.
I and a friend of mine bought the car, flew out to CA and made sure it was what Brett (IIRC his name was Brett) DROVE it home to MN, Put an opti in it etc. It went on the dyno and as we bought it made just short of 500 at the wheels. The air fuel was hella rich (IE 9.8-10.2 to 1) I cleaned up some of the tune and never quite crested the 500 hp mark, IIRC it made 494 or 496 at the wheels with a pretty safe A/F (still rich) we then made a few passes down the track just messing around getting used to the car, it ran a best for us of spinning 11.0's on Nittos with the cut out open....(no slicks to get up into the 10's again
Then later this last fall it sucked a valve, (stock retainers) and is currently in the machine shop for splayed caps, a 3.75 stroke crank, a set of oliver rods, and a better set of heads (AFR's with the big chamber) Unless I can find a cash tree the P600B will go back on blowing through the same 3 core intercoler untill I can swing a D1.......
RCFZ28, What are you running for heads? I have the AFR 190's with a 1.60/2.08 valves setup. This could throw me over the limit on smog.
EDSZ28 and RCF925, Thank you for sharing you cam specs.
