what supercharger is the best 4 95z28 !!!
Old May 24, 2023 | 10:19 PM
  #16
Re: what supercharger is the best 4 95z28 !!!
May be Keith Black hypereutectics. Not necessarily best for high boost applications. Can we assume your 383 is an LT1?
The thread is old but the posts above mention ProCharger and Vortech centrifugal superchargers. Not much has changed over the years. Which is best is debatable. What size depends on what boost level you're looking for. The more boost, the more you need to spend on rotating assembly, transmission, and rear axle assembly upgrades.
Old May 25, 2023 | 01:19 PM
  #17
FBODYSWAG's Avatar
Yes definitely a LT1 and without swapping the motor is it true the most power a 350 can withstand is 500hp?
Old May 25, 2023 | 02:58 PM
  #18
A stock, normally aspirated LT1 block and rotating assemble can support 500 HP at the flywheel. The key words there are "normally aspirated". Will not reliably support 500 HP with nitrous, turbos, or supercharger.
If your LT1 is a 383 build, the rotating assembly is not stock. If someone used an Eagle cast 3.75" stroker crank for example, even that may not support 500 HP normally aspirated. They are known to break.
The LT1 block however is extremely durable. I've seen one making 1,125 supercharged HP torn down, and no issues at all with the block. It was a Corvette LT1 bock, with 4-bolt mains. F-Body LT1's are 2-bolt mains.
Old May 26, 2023 | 05:06 PM
  #19
FBODYSWAG's Avatar
I looked on Hawks motorsports web site and they have decent performance packages. For 500 to 550 without a super charger. But ported 5.3l Cylinder heads? Don't they mean. 5.7 liter? Or they just using 5.3 as a example? I'm kinda confused on that because my motor is 5.7 not 5.3.
Old May 26, 2023 | 07:54 PM
  #20
The Hawks ad I found is packages that fit the LS1 series engines used in the 1998-2002 F-Bodies. Is this it?
https://www.hawksmotorsports.com/performance-packages/
Completely different engine than the LT1. Very few parts are interchangeable, definitely not the heads. The LS1 is referred to as a 5.7L engine, but the displacement is 346ci. The packages using 5.3L heads in the 500 & 550 HP kits refers to using ported heads off a 5.3L LSx truck engine. Can’t put those (or any other LSx heads) on an LT1.
Old May 27, 2023 | 12:34 PM
  #21
FBODYSWAG's Avatar
well damn...I gotta have a ls swapped motor..LT's aren't being souped up anymore huh..
Old May 27, 2023 | 01:36 PM
  #22
I'll have to disagree:
https://www.firebirdnation.com/threa...4#post-1573700
Old Jun 1, 2023 | 08:42 AM
  #23
The SRZ's Avatar
Ellwein Engines Home Page
HotwhipT/A
Jul 21, 2005 08:18 AM
PredatorZ28
Mar 18, 2004 06:46 AM
sideways_Into_3rd
Pacific
Aug 20, 2003 11:39 AM
D James
Jun 18, 2003 05:06 PM
Robbie
Apr 22, 2003 03:24 PM
