What size injectors? Vortech s-trim
Old Jul 6, 2004 | 09:51 PM
1fast Firechicken's Avatar
Here is the set up I will have
383 LT4(blocked rated for 1000+hp)
LT4 heads and intake
Vortech S-trim 12-16lbs not sure yet
Spearco 3 core 3" innercooler(huge)
Mufflex 4" exhaust
I am going to stay with the stock computer for now.So I know I need high impedence.57lb I believe is the biggest for HI IMP.
What would you go with?
Old Jul 7, 2004 | 09:23 AM
stealth2's Avatar
I owned a S trim on a 346 LS1 with a 100 shot and used 42# injectors. No way will it make 12-16 lbs, and certainly not on a 383 with ported heads.
Old Jul 7, 2004 | 10:15 AM
MEAN LT1's Avatar
Re: What size injectors? Vortech s-trim
Mufflex 4" exhaust
Actually you can get some 72lb high impedence injectors now from a&a performance. What kind of hp are you looking to get out of this setup?.
Old Jul 8, 2004 | 08:27 PM
1BadAzzGT's Avatar
Todd,
52# are not the highest ... high impedence injectors you can buy now. You can get much higher. I would say that you should go at least to 55/60# injectors for the kind of power that you intend on making. I can't wait to see/hear your car once it's done.
Cheers,
Tim
Old Jul 9, 2004 | 04:02 PM
2MCHPSI's Avatar
I have seen 12 lbs with just a 3.1 and 7 inch pulley on a 383, fully ported heads through an aftercooler............ 16 lbs????, most likely not, 12-14 lbs with a 2.75 pulley..I can easily see that. His LT4 heads are not ported either.
Old Jul 9, 2004 | 09:14 PM
1BadAzzGT's Avatar
Originally posted by 2MCHPSI
I have seen 12 lbs with just a 3.1 and 7 inch pulley on a 383, fully ported heads through an aftercooler............ 16 lbs????, most likely not, 12-13 lbs with a 2.75 pulley..I can easily see that. His LT4 heads are not ported either.
Kev,
You know as well as I do, if he intends to rev that engine like I think he does, I sure hope he updates to heavy duty springs and also gets those heads ported/polished. By the way, you ever coming over to pick up this chevy junk in my garage? LOL.
Old Jul 9, 2004 | 09:30 PM
2MCHPSI's Avatar
LMAO!! I am waiting for the GeeTee to be running right first so I can see how it runs
Can you PM me on Tealnet to get your number again?? I know I have time on Sunday.
Thanks,
Kevin
Old Jul 9, 2004 | 09:34 PM
1BadAzzGT's Avatar
Thanks,
Kevin
My turd has been running but running extremely lean @ lower rpms. Going to dynotune on July 20th. You have a PM on Tealnet ******* faulker.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
drptop70ss
Mar 26, 2015 01:50 AM
