What size injectors? Vortech s-trim
Here is the set up I will have
383 LT4(blocked rated for 1000+hp)
LT4 heads and intake
Vortech S-trim 12-16lbs not sure yet
Spearco 3 core 3" innercooler(huge)
Mufflex 4" exhaust
I am going to stay with the stock computer for now.So I know I need high impedence.57lb I believe is the biggest for HI IMP.
What would you go with?
Mufflex 4" exhaust
Re: What size injectors? Vortech s-trim
Mufflex 4" exhaust
Mufflex 4" exhaust
Todd,
52# are not the highest ... high impedence injectors you can buy now. You can get much higher. I would say that you should go at least to 55/60# injectors for the kind of power that you intend on making. I can't wait to see/hear your car once it's done.
Cheers,
Tim
Cheers,
Tim
No way will it make 12-16 lbs, and certainly not on a 383 with ported heads.
Originally posted by 2MCHPSI
I have seen 12 lbs with just a 3.1 and 7 inch pulley on a 383, fully ported heads through an aftercooler............ 16 lbs????, most likely not, 12-13 lbs with a 2.75 pulley..I can easily see that. His LT4 heads are not ported either.
You know as well as I do, if he intends to rev that engine like I think he does, I sure hope he updates to heavy duty springs and also gets those heads ported/polished. By the way, you ever coming over to pick up this chevy junk in my garage? LOL.
Can you PM me on Tealnet to get your number again?? I know I have time on Sunday.
Thanks,
Kevin
LMAO!! I am waiting for the GeeTee to be running right first so I can see how it runs
Thanks,
Kevin
Thanks,
Kevin
