what are others doing to vent the crank case?
Old Nov 7, 2008 | 11:01 AM
97SS0594's Avatar
ive been searching and searching and cant find a consistant answer, running the PVC is out of the question, will a breather in the valve cover be enough?
and pictures help!
Old Nov 7, 2008 | 12:59 PM
Roadie's Avatar
One breather wasn't enough for me. I was blowing oil at ~15 psi.
I wound up running 2 breathers. One was a standard breather and the other was a breather with a 5/8" hose barb on it. I ran a 5/8" heater hose back to the turbo inlet to pull air out of the crank case.
It is similar to the exhaust based evac systems. I like those as well.
Old Nov 7, 2008 | 06:25 PM
Funkybird's Avatar
I have the pcv routed under the throttle body like stock and a line from the passenger valve cover goint to the inlet of the blower with and oil/water seperator in between. Works flawlessly for my ~18psi.
Old Nov 7, 2008 | 10:01 PM
97s10ondubs's Avatar
I still have the pcv, but i have breathers on all four holes in the valve covers, still get some oil on the valve covers, but not too serious.
Old Nov 8, 2008 | 08:33 AM
mzgp5x's Avatar
Vac pump. GZmotorsports VP103.
http://s306.photobucket.com/albums/n...p%204th%20gen/
Old Nov 8, 2008 | 10:13 AM
engineermike's Avatar
With the factory-style setup (with PCV, 1 valvecover venting to the inlet of the turbo), I was blowing oil out around the dipstick tube. I added another valvecover vent on the driver's side using an OEM vented valvecover and ran it to the inlet of the turbo also and now it works fine.
Old Nov 8, 2008 | 01:43 PM
boosted-lt1's Avatar
I rigged up a system that use the exhaust to evacuate the crankcase. Seems to work pretty good. You can feel a little suction on the valve cover end at idle. I have a one way valve welded to the downpipe and 3/4" hose running up to the passenger valve cover. No need for a breather with this type of evac.
-Scott.
HectorM52
Jul 30, 2017 11:46 AM
jmadoll
May 27, 2015 07:13 PM
