oil pan questions for my D1 383
I've got canton pan #15-242 and the pickup tube ive got is front sump mount, does the recommended pickup tube mount in the back of the pan? does anyone know?
I have same set-up. Also, 383 with D1 and Canton road pan. Had the same problem with the pick-up (purchased the wrong one for a Melling high vol pump). Canton helped. I run my D1 oil return line (1/2 alum hard pipe) to a fitting on the passenger side near the starter. Have not had any problems. B
