What to do - What to do??
Old Aug 19, 2003 | 08:04 AM
Brady's Avatar
I went to the track Sunday and bent a couple pushrods right off the bat. This is the first time this has happened. I'm actually getting very close to tearing everything up at least once..
Anyway, I bent the intake and exhaust pushrods on #8 cylinder. They were the cheapo $30 comp cams heat treated pushrods..
I pulled the spark plug on #8 and it looks fine and I can't really see any other damage so should I just put new pushrods in and go for it?? I really *really* don't feel like pulling the motor out and tearing it down.. But I also don't want to shell the motor or wipe out a turbo.. I'm leaning towards putting new pushrods in it and starting it and seeing how it acts.. I got new 1 piece chromoly pushrods from thunder Thanks Paul!
Are these cheapo pushrods prone to bending/breaking??
I think I hit the limiter on the 2-3 shift (6500) and I know I revved it a little higher (shiftlight set at 6300 vs. 6000) The valve springs are fresh too, FWIW..
thanks
...Brady<--- destined to run 10's forever...
Old Aug 19, 2003 | 09:26 AM
Tiago's Avatar
replace them and try
Old Aug 19, 2003 | 10:16 AM
dobe's Avatar
i say replace them and see if it all work right..
i broke one pushrod and one rocker stud once and replaced and everything in my car seemed to be okay so far i also went with a one peice pushrod and a bit longer one
Old Aug 19, 2003 | 11:47 AM
Joe Racer's Avatar
You could do a leakdown test on that cylinder while you have the rockers removed. That would tell you if you have bent either of the valves.
Old Aug 19, 2003 | 12:52 PM
rskrause's Avatar
Moderator
Well, why do you think you bent them? Usually, this is because a valve hit a piston or there was some other contact that should not have occurred (rocker to valve seal, etc.). I suppose if you have mondo springs and really cheesy pushrods that could be the culprit, but I doubt it.
I think you need to figure out what's wrong before you break something big time, if you haven't already.
Rich Krause
Old Aug 19, 2003 | 12:57 PM
95 Silver TA's Avatar
Brady,
I know its off the topic but I just got the new GM Hightech Mag.
All I have to say is DAMN!!
Very SWEET Ride Man!!....DAMN SWEET!
And Congrats on the write up in the Magazine.
Thx,
Claude
Old Aug 19, 2003 | 10:00 PM
EDS Z28's Avatar
Upon teardown of my motor during the first rebuild, I found 3 bent pushrods. They were replaced with crane chromoly units, and I have never had a problem since. You may want to call comp cams and find out just how strong those ones in the $30 set are compared to the chromoly ones.
I also saw your car Brady in GM High Tech. Congradulations on that car. Hope you can get it fixed.
Old Aug 21, 2003 | 09:41 AM
Guido's Avatar
I bent a pushrod once but it was a result of them being too long.
If you have never had this problem before, Im not quite sure what could have caused it. Id say its at least worth a leakdown to make sure you dont have some bent valves or something else amiss there.
Good luck bro.
Old Aug 21, 2003 | 11:48 AM
Brady's Avatar
Thanks guys, I put new pushrods in it and it seems fine.. I think the $30 pushrods didn't like the 977 springs.. I could be wrong though, time will tell.
Old Aug 21, 2003 | 12:35 PM
ru2slo_99's Avatar
Check the lifters. The spider that holds down the hydraulic lifters got bent somehow on my #3 cylinder. The lifters spun around in the bore and eventually mushroomed the lifter and the lifter would get stuck in the lifter bore. I could crank the car and watch if run fime for about 1 min. then it would either bent or break the pushrod.
Old Aug 22, 2003 | 09:37 AM
Pro Stock John's Avatar
Might want to check lifter preload.
Good luck on running 9's!!!
