what blower makes the most
can any of you guys tell me wich S/C makes the most power out of the box on a stock lt1. opinions anyone? i have decided to go forced in my ride can i get a strait answer?
To restate the above, just about any SC can produce enough boost to seriously decrease the lifespan of a stock motor.If you really mean to ask about comparing low boost setups, I'd answer the following. The "safe" boost limit for a stock LT1 is ~6psi. At that level, there will be no significant difference between a Vortech or a Procharger, assuming they are both intercooled. The thing is, the Vortech "aftercooler" is expensive, so the Procharger kit may be a better deal.
Rich Krause
Rich Krause
My best pull ever was 441 at the wheels with 7 PSI from my S trim. That was with alot of bolt ons as well as a near perfect blower tune and zero belt slip.
My last dyno was a dismal 353 horses at the wheels which I receintly found out was from my springs and valves not closing all the way.
They would close, but the valves would bounce off the seats and allow boost/compression to escape from the combustion chamber. Too bad I had to blow a head gasket to figure that one out.
I can't wait to get back on the dyno with my new ported heads/valve job/good springs and my for real blower cam. Gonna be interesting.
1LEThumper
Jul 14, 2003 12:45 PM
