Want to remove plastic cover in front of radiator (cross flow for intercooler)
Old Aug 9, 2010 | 12:21 PM
siguy's Avatar
I have have a 95 T/A that i removed the fog lights and cut a hole where the licnce plate is. (have a 2 core intercoooler in the bumper (support removed)
I want to remove want to remove plastic cover in front of radiator so that i can get direct flow through the inter-cooler and radiator is this a good thing for better cooling or will this disturb air flow etc..
Old Aug 9, 2010 | 01:15 PM
Procharged94Lt1's Avatar
I pulled out all the plastic in there when I put my FMIC in. The only thing that is left is the lower air dam and my car still cools just fine even with the factory radiator and WP.
Old Aug 9, 2010 | 05:01 PM
siguy's Avatar
ok cool did you see an improvement in your intake temps and or cooling or everything stayed the same?
Old Aug 9, 2010 | 05:06 PM
I honestly didn't measure them..seems to cool pretty good though- however I also have a stinger hood and I can look thru the cowl and see light thru the headlight buckets so that I'm sure improves air flow as well.
Old Aug 10, 2010 | 03:39 PM
siguy's Avatar
ok cool thx
Old Aug 10, 2010 | 08:26 PM
MikeGyver's Avatar
I removed mine.
Old Aug 11, 2010 | 12:40 PM
siguy's Avatar
Originally Posted by MikeGyver
I removed mine.
cool thank you for the pictures
Old Aug 11, 2010 | 10:00 PM
onefastmx5's Avatar
I've removed ALL of my plastic underguard. Temps increased a small amount. Put on a RKsport front lip and temps go up even more now on HOT (95+) days, especially on the freeway. I installed 2 puller fans on the intercooler hoping to A. Keep IC from heatsoaking (its working) and B. Reduce radiator temp a little when it gets a touch hot (does not work). With the 4" core, i had to ditch the foglamps, so i have my fans wired to the old fog light connectors. I simply turn on parking lamp and fog light switch to engage.
ModdedNerd
Jan 29, 2015 07:23 PM
rjc1629
Jan 27, 2015 10:46 AM
Jul 4, 2005 05:00 PM
MJ_Z28
Aug 8, 2002 09:02 PM
