Twin turbo header pics
I appoligize for the fuzzy pics, these were taken with a video camera. Follow the link to the 3rd page of posting for the pics.
http://www.midwesthorsepower.net/for...t=520&start=20
The header flanges will be replaced with some 1/2 thick one's. The drivers side will need to be Tig'ed yet. The Pass side will need to be finished, we have 1 primary on it, but we may need to get the turbo sitting alittle more parallel to the ground, It's at an angle.
We are using the stock accessory bracket with Alt, P/S and tensioner. We will need a 1LE pulley, and have to modify that to get the downpipe in there.
AC compressor is deleted, and Battery will be relocated to the trunk. The power steering lines will also be needed to be relocated, but shouldn't be to hard to do.
Me and a friend are building 2 identical systems, his car was the first we started on, but mine will be similar, I just have different turbo's.
Let me know what you think
Bill
Bill
Originally posted by SMOKNZ
I'm running 2 precision SC-61's. They have .68 A/R Tangential turbine housing, as well as V-band clamp outlets.
Well for now it will be my same old 355. I run AFR 190 heads and a 224/220 .544/.544 114LSA cam, Speed Pro Forged -22cc pistons, stock crank and rods with ARP bolts. I don't plan on taking this combo over 600 Hp. After the Turbo's are finished I will be pick up a LT1 block, and have it machined .030 over and for splayed main caps. I'm planning a 383 with forged JE extreme duty -31cc pistons, and eagle forged crank, and either forged eagle H-beam rods or Oliver Billet rods. Then I will have everything ballenced. Once the motor is done, It only takes a weekend to swap in the new one.
Bill
Bill
http://www.bytehead.com/~dunk/
Follow the link to the 2-12-04 update. I finished welding my pass side header today. The Drivers side will commence as soon as I get that damn dowl out of the head (It somehow jammed in there flush!!) It only took about an hour and a half to make the header, but many more hours TIG welding it up! Turbo sits right where the battery was, and this header sneaks along the side of the accessory bracket. Creative modification of a 1LE Bracket will allow use of a 3" downpipe as well.
Pics are MUCH clearer than the last one's (got a new camara, so no video capture photo's). I'll get some in car pics as time goes on
Bill
Bill
Bill, nice to see the project coming along
Are you going to try and utilize the factory surpentine setup?
Do you plan on joining the hot rod power tour this year? A few of us are starting in Iowa and ending with the rest in Milwakee.
Are you going to try and utilize the factory surpentine setup? Do you plan on joining the hot rod power tour this year? A few of us are starting in Iowa and ending with the rest in Milwakee.
I didn't know about the power tour was coming this close. Anymore info on it? I bet a few of my friends would love to make it, I would as well!
Bill
LT1runner
33
Jul 24, 2002 01:19 PM
ced8
Jun 24, 2002 11:11 AM
