turbo question
Old Aug 22, 2007 | 12:37 PM
  #16
engineermike's Avatar
Originally Posted by 12sec94z28
Would it be better to make this a front mount set up?
YES.
If so would the specs on the turbo need to be different like the a/r?
You can't really go wrong with a T76GTS with the .96 housing. An ST80 would be better, but it's a physically larger turbo and harder to fit in the engine bay.
It went high 9's so i would like this one to do that too.
High 9's is not a problem for the 76GTS.
Mike
Old Aug 22, 2007 | 12:46 PM
  #17
RealQuick's Avatar
Also, with the front mount turbo, the T76GTS would be perfect for 355-383ci looking to make 700-800rwhp, and Forcedinductions.com has an 80mm GTS upgraded comp wheel i believe.
Old Aug 22, 2007 | 01:53 PM
  #18
12sec94z28's Avatar
i am going to fab this stuff up is there any good sites that show pics of set ups? I will probably have to cut the core support and move the radiator correct?
Old Aug 22, 2007 | 01:56 PM
  #19
snorkelface's Avatar
Originally Posted by maro z28
I was seriously looking at the T-76GTS kit from PTK. Let me know any #s or track times or install or pics or whatever...just holler at me. Very interested in your set up, thanks.
Just look at this thread:
http://web.camaross.com/forums/showthread.php?t=530043
The car is nearly finished, and there should be more pics up today or tomorrow.
We ended up having to move the radiator, which I believe there will be pics of because we didn't want to use the one pusher fan that they supplied and I wanted to keep my AC.
Old Aug 22, 2007 | 01:58 PM
  #20
Originally Posted by RealQuick
You wont have a problem hitting your numbers....
I'll point my builder to this thread and tell him not to embarrass me!
Old Aug 22, 2007 | 02:35 PM
  #21
RealQuick's Avatar
It depends on how good you are. I can build a log manifold kit that keeps the stock A/C and stock fans ... but my header kit requires modifying the radiator/fans (although I used a T88 turbo).
Old Sep 4, 2007 | 10:48 PM
  #22
TurboSS's Avatar
Noted
LeftoverChinese
Jan 14, 2024 03:03 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Newgmman
Feb 25, 2015 02:53 PM
blac94Z
Jan 22, 2015 11:19 PM
