Turbo placement at the rear????
Old May 29, 2003 | 12:30 AM
  #16
Whistler's Avatar
If you buy this setup make sure you park your car in the garage or some riceboy will come steal your turbo.
Old May 29, 2003 | 06:25 AM
  #17
SMOKNZ's Avatar
I'd really like to see a pic how everything is run. I think it sounds really interesting, but even with that long of a run for pressure piping and no intercooler, I would still run the water injection. If you would ever work on my car with the lack of room under the hood this rear turbo sounds like a heaven sent idea Its really interesting though. Imagine a turbo system with hooker long tubes!!!
Bill
Old May 29, 2003 | 08:32 AM
  #18
BBB's Avatar
BBB
All you guys are soooo right. Can't work...etc. I'll let you know how bad it sucks here in a couple of months.
BBB
Old May 29, 2003 | 04:14 PM
  #19
zturbo's Avatar
As the Imortal Buford T. Justice said in Smokey and the Bandit.. Junior Remind me to kick ya momma in the butt. (all in fun guys)
I just do not see this system working and read alot of responces but some were taking word for things that i just don't know about..
First and foremost the oil situation.
Turbo in the rear of the car wonderful... How are you going to pump the oil there and back going to have to have one heck of a pump to push the oil that far back at a nice pressure. Then since there is no pressure on the return of the oil you are going to have to pump the oil at a high volume back and this is prob going to need a very nice pump to handle the heat and load of constant use.
Next issue Lag..
Ok think of it like this. Two air compressors same compressor setup, BUT one has a tank and one does not. Now we know that there is a volume of air on both the exhaust and the intake of this setup that we can show as the tank setup.. Which one reaches 100 psi faster. Once the car is on boost it prob can keep up with the boost but you are going to have to load the car seriously hard to get boost and keep it IMO. Just chassis dyno a turbo car you will see what I mean, then go on the highway in 5th gear and wot. Using a/r housing to make up for spool time great.. but at some time it is going to flip flop on you whether or not it becomes a restriction.
AS for gaining 14 mph in the 1/4 you can load the turbo for whatever amount of time and then launch, as Mike said once loading up the car and getting boost you are not worried about spool up since most of the time you are wanting to leave the line SPOOLED UP.
As some others have said isn't Heat energy... If you are trying to get rid of heat aren't you loosing energy...
Hope it works for the guy but I just do not see that happening.
Steven
Old May 29, 2003 | 08:06 PM
  #20
GhostZ's Avatar
Well I wasn't able to get down there today, hopefully I will be able to make it down there tomorrow and I'll see if I can get any pictures of the setup....if anything, I'll just describe it as best I can.
I'll make it a point to check on oiling of the system.
Old May 29, 2003 | 08:08 PM
  #21
BBB's Avatar
BBB
This is a reply to the oiling question on our local site. The thread is located at
http://www.ufba.org/forum/index.php?...=3476;start=20
As for oiling question, yes we do run an oil pump. Our oil system, as well as remote mount, is patent pending. It includes a wet-start system to instantly lubricate turbo at startup. It also cools the oil before it gets to turbo and then again before it returns to engine.
I will try and get some pictures up on our web site soon. We are still in middle of building the web site. You are welcome to come by the shop and check out our stuff if you are in the area
Rick @ STS 801-979-6554
Call Rick
BBB (I'm not Rick and have no association with his company)
Old May 29, 2003 | 08:18 PM
  #22
Fast Caddie's Avatar
What if they tapered the lead pipe? Say you leave a 4" collector at the y-pipe and taper it down gradually to the turbine inlet, which may be 2.5"? That would cover about a 6-7 foot tract I think, which should help to keep velocity up as the gases cool. Or you could even ceramic coat the pipe to keep as much heat in as possible.
But I, too, am a little skeptical of this setup. Seems like it would suffer the same fate as the Turbo Tech kit; it's great for a bolt-on car but would really be hurting in the higher hp apps. Close to the engine is where a turbo belongs, IMO.
Not saying it sucks or anything, but about all that has been said in this thread is exactly what I've been experiencing for years in the build-up of my Buick. It should suffice in a mild 11 or even 10 sec V8 setup, but I wouldn't look too much further than that before having big headaches with tuning. Maybe with a big-cube stroker and GOOD heads in a good state of tune, but not a whole lot farther.
Just my $.02
Old May 29, 2003 | 08:47 PM
  #23
WS6 TA's Avatar
Although I agree with the general sentiment (not a good idea)… it’s not as bleek as people want it to sound.
The pressure just needs to stay between 20-50psi when the turbo is under load.
Assuming that you run a typical ¼” (an-4) feed, we’re talking about an additional .02quarts of oil… and the return pump will have to move roughly .5gallons/minute… really a rather insignificant amount.
Next issue Lag..
As long as you’re not running an intercooler with this setup (unnecessary with mild boost at high altitude), this is a non issue. The volume of the intake charge tube (probably 2.5” at most) running the length of the car is likely smaller then the volume of most intercoolers.
I still really doubt that you’ll get significant cooling running a long tube through that (relatively hot) area.
Obviously, he’s running a small enough turbine housing that it’s spooling fine with a relatively small exhaust volume, so that’s not an issue till you try to make more power.
Again… the combination works OK for an engine at high altitude… I’d like to see him drive it down to sea level and run it at a track without race gas and not blow it up.
This is EXACTLY why it will never be a killer, all out turbo setup. The fact is that we’re really awful at getting the energy out of the gas that we’re burning. We manage to get roughly 10% of that energy out to someplace that we can use it. If you allow it to dissipate as heat before you use it that small percent that you actually manage to harness becomes that much smaller.
Old May 29, 2003 | 10:24 PM
  #24
teamsleep13's Avatar
A third of an engines power out put goes to the crank, while the other two thirds go to the cooling system and out through the exhaust.
The purpose of a turbocharger is to harness wasted energy (heat) from the engine, which is exhaust. To harness that enregy the most efficiently, you want it straight out of the exhaust ports and into the turbine. This will give you the most effcient use of the exhaust gases.
Now if you put the turbo at the back of the car, of course it will work, and it will probably work quite well if done properly, but as some have said, no where near what could be done with a turbo as close the the cylinders as possible.
Loosing all that heat with a turbo at the rear isn't really worth the benefits(which im still trying to come up with) it could bring. I like to have things as efficient as possible, and keeping the turbo up front is more effcient.
From all of this I still say, to each his own. Diversity is what keeps the automotive industry thriving.
Hunter
Old Jun 1, 2003 | 08:16 PM
  #25
GhostZ's Avatar
Well I went down and checked out this setup the other day and I didn't have my camera with me so I'll describe the setup as best I can.
The intake tubing replaces the stock I-pipe and runs along the same route coming up over the axle and parallel with the axle toward the drivers side which is where the turbo is mounted. The air intake for it is basically where your drivers side talipipe would be. The charge line runs the full length of the car along the drivers side of center line and comes up front and into the intake like a normal CAI would.
He states that he has never had any problems with debris into the filter nor has he had a problem with water splashing on the turbo (turbo is placed basically where your stock muffler would be).
There is an oil pump on the return line but the biggest problem I see is that there is no room for the charged line to run if you have headers....only stock manifolds.
And since we all know how heavy and restrictive the stock manifolds are, not to mention how much of a PITA it is to change plugs with stock manifolds....that and a few other things were enough for me to leave the shop.
So if anyone is wanting this turbo kit, they better keep their stock manifolds or sell their newly installed FLP's (BBB )
As for me....I'm still waiting to see what www.turbolocity.com is doing with their setup.
Old Jun 2, 2003 | 07:52 AM
  #26
BBB's Avatar
BBB
That is what I am going to see about. We talked last week for a while and it seems that he is interested in stepping up to header cars. We will see....
BBB
Old Jun 2, 2003 | 09:00 AM
  #27
got_hp?'s Avatar
here is my dialogue with him, just in case people are too lazy to goto the other board.
me: does the system only work with stock manifolds, or will it work fine with after market long tube headers?
also.........without testing this kit at sea level, what changes have you made to insure that it will operate properly for other people who order it.........or is it just for local guys?
him: This kit is designed to be used on a stock LT1. It clamps on to the exhaust system just like the stock muffler clamps on. The problem with headers, a couple anyway, is that the air charge tube probably won't have room to run up into the engine compartment with headers on. Also, headers have a hard enough time not leaking with no pressure in the exhaust system, let alone the backpressure produced by a turbocharger. Headers won't really give you a performance gain on a turbo application like they do on an aspirated or supercharged application because your exhaust system is really only as good as the smallest orifice (restriction) and the turbo is alot smaller than even the stock manifolds. The rules are changed when you enter pressure into the equation. That is one nice thing about turbos is that you don't have to spend alot of additional money on expensive exhaust, big cams, and high flow heads. You also get to retain the driveability and fuel mileage of a stock vehicle.
As far as sea level goes, we are still in pre-release stage of the kit and looking for a good test vehicle at near sea level elevation. They obviously won't be able to run the boost there that we do here w/out some modifications. Stock system should handle about 5 psi boost at sea level.
me: hmmmmm..............id say that you are going out of bounds saying that a turbo system does not benefit from larger headers/exhaust manifold.
in ANY turbo application i have every seen, you can always pick up power when switching from the stock manifold to a well designed aftermarket one.
no to mention, the stock manifolds are horribly restrictive, and terrible for plug access.
him Sure, there will probably be some gain in a better flowing manifold but not the gain you get in a non-turbo application. Think about it, The hole in the turbocharger that all of the exhaust (except wastegated) has to pass through is roughly the size of your thumb, so how big of primary tubes do you think you need if you have a 1" collector (so to speak)?
i left another post saying how 90% of the people that might buy his kit have aftermarket headers, and are not willing to go back to stock manifolds, so he will have to change things if he wants to sell it.
LeftoverChinese
Jan 14, 2024 03:03 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jun 6, 2015 08:27 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
