TURBO INSTALLED!!!!! V6 is ready.......
Old Aug 3, 2005 | 05:16 PM
viper03af's Avatar
tranny and rear is not
www.turbov6camaro.com/turbo
Finally got the turbo on there sorry for the large pics.
it pulls vary hard and the **** MAF maxes at ~9 PSI....
WB AFR is ~11.6 while boost is biulding and under 11 when the full boost
so i need some tuning, tranny, rear, and drags and then i'm after my goal of 10.99 for the V6
Old Aug 3, 2005 | 09:45 PM
EDS Z28's Avatar
Re: TURBO INSTALLED!!!!! V6 is ready.......
Stock V6?
It's going to have to be built for that much power.
With 20 psi, it could be very fast.
Just look at the turbo Buick V6, hell of a motor.
Old Aug 4, 2005 | 04:56 PM
viper03af's Avatar
Originally Posted by EDS Z28
Stock V6?
will not need 20 psi from a t-70 to hit 10's...... lol
maxing the maf is about 350 RWHP on these cars (330-348)
the motor has been waiting on boost
www.turbov6camaro.com/mod.html
Old Aug 4, 2005 | 10:22 PM
EDS Z28's Avatar
What you got in the bottom end of that motor? Hopefully forged pistons.
Remember a V6 has to be built stronger than a V8 because it is subject to more stress. Thats why the turbo buick came stock with a forged crank and pistons.
Old Aug 4, 2005 | 10:56 PM
5.0THIS's Avatar
Post up track times when you get them. I hope your T5 is built, or it will grenade running the slick you would need to hit 10s. I think you'll hit low 12s, high 11s.
Old Aug 5, 2005 | 11:53 AM
viper03af's Avatar
err did you guys even read my post
i siad i still needed tranny, 12 bolt and slicks.. those are next on the list.
Motor
Diamond coated piston 8.5:1 c/r w/rings and wrist pins www.3800performance.com
Forged L32 2004 GTP Connecting Rods www.3800performance.com
ARP studs, bolts ect.
Intense racing head gaskets www.3800performance.com
Comp Cams custom grind, www.3800performance.com
Comp cams Hydraulic Roller Lifters www.3800performance.com
Comp cams 130lb springs www.3800performance.com
Comp cams titanium retainers www.3800performance.com
Comp cams push rods www.3800performance.com
Cam install kit w/timing chain www.3800performance.com
Clevite 77 TriMetal Main Bearings
Clevite 77 TriMetal Rod Bearings
Clevite 77 TriMetal Cam Bearings
Oil PSI kit to 80 PSI at WOT www.intense-racing.com
New oil pump kit
Mobil 1 15w50 & K&N Oil filter
PCM
HP Tuners PCM Programmer
Greddy Black Profec B-Spec II electronic boost controller www.ftpp.net **Wating to Install**
FUEL
57 lb/hr injectors http://www.racetronix.com/
********WAITING TO ORDER************
Racetronix Fuel pump kit http://www.racetronix.com/Racetronix..._Pump_Kit.html
Induction
T-70 Force Fed Fabs Turbo kit http://www.force-fed-fabrications.com
Race port/polish heads w 5/3 angle valve job
K&N air filter
Exhaust
Pacesetter headers www.ftpp.net
Open down pipe
Ignition
MSD Heat Guard Kit www.ftpp.net
MSD DIS 4 www.summitracing.com
MSD Custom Wires www.summitracing.com
MSD Blaster coils www.summitracing.com
MSD Coil Interface Modules www.summitracing.com
Gauges
A/F ratio www.summitracing.com
Boost www.summitracing.com
Fuel PSI www.summitracing.com
Digital RPM gauge with LED shift light built in http://www.sw-performance.com/Prods/11UltrShft.html
AEM 2 1/16" Wide Band AFR www.ftpp.net
Outside
Smoothie II's wrapped in Eagle F1 GS-D3 275/40ZR-17's
Light black outs all the way around
Viper yellow with black racing stripes
Mud/rubber flaps with "CAMARO" on Rear only
"Camaro" rear inserts
3800 side stickers
30th Ann stickers
Inside
Custom painted Yellow by me
White face/ reverse glow gauges www.ebay.com
Peddles
Corbeau adj.racing seat (yellow)
Corbeau black 5-point harness. www.ftpp.net
Corbeau seat mounting brackets. www.ftpp.net
*******WAITING TO INSTALL*****************
Autometer 3 gauge pillar pod www.ftpp.net
System
Panasonic 60w * 4 w/ 3dot matrix display
Kenwood 1000w RMS amp www.ebay.com
2 reference Infinity 12's www.ebay.com
Kicker components
3 Farad CAP www.ebay.com
Drive Train
Prothane Tranny mount www.summitracing.com
Z28 Rear End/axles/brakes www.camaroz28.com
LS1 1 piece Drive Shaft www.camaroz28.com
STAGE-5 SPEC Clutch www.ftpp.net
Mobil 1 Tranny and rear-end fluid.
Suspension ******* waiting to order****/^^^^and/or install^^^^^
KYB AGX 8 way Adj. shocks on front and rear
New rear spings
Spohn 8 point roll bar. www.ftpp.net (Door bar's not installed yet)
Spohn LCA w/install www.ftpp.net
Brakes
Hawk HPS pads both front and rear. www.ebay.com
Cross drilled/slotted rotors both front and rear. www.irotors.com
Rear Disk Brake's www.ebay.com
Old Aug 5, 2005 | 11:54 AM
viper03af's Avatar
place that biulds T5's is hard to find
LeftoverChinese
Jan 14, 2024 03:03 PM
4586
Nov 18, 2023 07:21 PM
Highlander
Jan 12, 2020 02:13 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
blac94Z
Jan 22, 2015 11:19 PM
