Turbo Hotside
Old Sep 21, 2006 | 06:26 PM
  #31
jerminator96's Avatar
Re: Turbo Hotside
Originally Posted by engineermike
All of the exhaust can go through the wastegate. There is no check valve in the crossover pipe.
What i'm saying is that the entirety of drivers side header bypasses the wastegate. Maybe it doesn't make any difference, but I would assume that a wastegate placed in between the turbo and the drivers side would be more effective. And you never said how big it was?
Old Sep 21, 2006 | 06:31 PM
  #32
engineermike's Avatar
Re: Turbo Hotside
It's a 40mm Tial. There is nothing stopping the driver's side exhaust gas from going through the wastegate. The gas will follow the path of least resistance.
Mike
Old Sep 21, 2006 | 07:05 PM
  #33
Re: Turbo Hotside
Mike
Ah yes, that's true. I always forget the simple physics
Old Sep 22, 2006 | 02:35 AM
  #34
Chrisbequick's Avatar
Re: Turbo Hotside
Originally Posted by LT1-TA
Chris.... how did you route that big ole downpipe between the steering shaft and crossmember and what not?
Sorry I missed the downpipe pics.
Here it is when it was finished. At the time of this picture the downpipe was mild steel and necked down from 3.5" to 3" here and was a slip-fit. Now it's 3.5" stainless all the way to the cat back and is V-banded.
A bunch of guys said I couldn't fit a 3.5 inch downpipe in there. HA!
-Chris
Old Sep 22, 2006 | 02:43 AM
  #35
Re: Turbo Hotside
Originally Posted by 94irocz
Chris what kind of headers are those are where did you pick them up at. And how does the P side header come in? That looks like a real nice set up you have there. Also how big of a turbo will sit in that area where the cai is supposed to be?
The headers are Hedmans for a Vortec equipped '96-98 Chevy half-ton with a 305. They're the only SBC headers I could find for a reasonable price that had the passenger's front primary (now the driver's rear primary) come up and over the middle primaries. Obviously they're reversed. The passenger's side (on the car) is perfect once you remove the A/C (the collector dumps where the A/C pump mounts) and hack the AIR pump fitting off the header and weld the hole closed. The driver's side (again, on the car) fits perfectly. It started rubbing the steering shaft a little, so I dimpled the number 5 primary where it gets near the shaft. Other than that they fit like they're made for the car. The passenger's rear primary even has a nice eighth-inch clearence from the heater box. The only downside is that the collectors are two-inch ball and socket flanged. I was in a hurry to get it done and out of the shop so I used them with the little collectors for a couple of years, but during the current rebuild we hacked off the collectors and fabbed in a 2.5" stainless collector with a V-band.
Cliff's notes: They're for a pickup. Hack 'em up and they'll fit.
-Chris
Old Oct 26, 2006 | 08:59 AM
  #36
blkchevyz's Avatar
anyone try these?
http://cgi.ebay.com/ebaymotors/SBC-T...ayphotohosting
they are probably a little big but i would think some modding might get them to fit.
Old Oct 26, 2006 | 09:11 AM
  #37
97WS6SCharged's Avatar
SSAutoChrome =
Old Oct 26, 2006 | 09:21 AM
  #38
blkchevyz's Avatar
gotcha
just trying to figure out my options here.
Old Oct 26, 2006 | 12:05 PM
  #39
Roadie's Avatar
I'd give them a shot on something with a big engine bay (64 impala, 72 chevy pickup, etc)... I doubt they'd get anywhere near fitting on a 4th gen.
Old Oct 26, 2006 | 03:27 PM
  #40
Well there's that, there's also been alot of complaints that their welds and even their tubing cracks. Check out the power adder forum on thidgen.org.
Old Oct 26, 2006 | 04:12 PM
  #41
leadfoot94's Avatar
Just finished the mock-up for the passenger header. 1-3/4 SS primaries/Burns Merge Collector.
Now I just have to fab the drivers side, hook-up the crossover and mount the 4" down-pipe.
I was originally going to use SLP shorties, but changed my mind after I didn't like the way they were built.
Old Oct 28, 2006 | 09:38 AM
  #42
94irocz's Avatar
do you have any more pics of how that goes under the car?
Old Oct 28, 2006 | 09:16 PM
  #43
leadfoot94's Avatar
Its disassembled right now for welding but basically it just hugs the block and is angled between the oil pan and the access. bracket. The crossover then runs in the space between the oil pan and the balancer pulley like everyone else.
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
