Turbo Hotside
Turbo Hotside
So I'm thinking about building my own turbo setup. What do you all think about using the "Block hugger" shorties as turbo headers?
If anyone can post pictures of how their single turbo LT1 f-body system is routed through the engine bay i'd appreciate it. I'm really just trying to get ideas. By the way i'll be using a T-4 frame turbo, but T-6 frame setups would be fine too.
Here's my initial inspiration.
Re: Turbo Hotside
Originally Posted by RealQuick
The last primary on the driver's side looks like it will hit the steering linkage coming out of the firewall... been there and done that.
Re: Turbo Hotside
Originally Posted by jerminator96
I like the first one, how's your radiator clearance?
Honestly it looks like it would hit stock fans based on measurements, but since the a/C gets deleted the radiator/fans can me moved forward for clearance.
Re: Turbo Hotside
Dang, Realquick, that 2nd setup looks shockingly similar to mine. Differences are my passenger's side header is a regular SLP single-cat shorty. Also, my turbo is not quite as crooked as yours. In other words, it's more in line with the car. I like it because it's very servicable. I can pull any 1 part of the system without disturbing the rest of it. I can pull the driver's side log header without removing the crossover pipe or turbo. I can pull the turbo without removing the log or downpipe. I can pull the crossover without. . . ah you get the idea. . .
If anyone can host pic's I'll e-mail my hotparts over.
Mike
Mike
Re: Turbo Hotside
Originally Posted by Roadie
Jon: Nice work on the second one... Looks like you've been quite busy in that shop of yours.
Re: Turbo Hotside
Where does the passenger side exhaust wrap around to the drivers side, under the oil pan? Or behind the pan?
Re: Turbo Hotside
Mike
Mike
I angles the turbo torward the driver's side fender to avoid any problems with the DP and steering shaft...it was easier that way for me.
