turbo cam question
turbo cam question
I have a comp cam .569/.572 lift 224/228 duration and 112 lsa. Will this work with a turbo setup or do I have to change my cam just to run a turbo. I only want to run 5 or 6 pounds of boost and I do not want to have to change cams. If I do need to change it what would everybody reccomend. Thanks
You don't have to change the cam just to run a turbo. The cam you have won't be optimal for a turbo setup, but it will still work. You may bleed off some boost down low with the 112 LSA, but the nice thing about a turbo is it only takes a slight turn of a dial to increase the boost.
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
