Turbo Build For Jason Short
Old Dec 28, 2011 | 09:08 AM
  #16
RealQuick's Avatar
Re: Turbo Build For Jason Short
Old Dec 28, 2011 | 02:57 PM
  #17
Jason Short's Avatar
Unbelieveable Jon! I can't believe how well that drivers side header turned out! That is exactly what I had in mind, and initially I thought that I would have to sacrifice plug clearance on that side due to my header style and routing criteria. The plug access you were able to get out of it is just incredible!!
You've exceeded my expectations
Old Dec 28, 2011 | 10:01 PM
  #18
RealQuick's Avatar
Glad you are happy jason!
Changed the crossover a little, and need to make one tweak to the DP, but here is the initial mockup.
Old Dec 28, 2011 | 10:03 PM
  #19
RealQuick's Avatar
Jason, what size gate are you gonna buy? Also, what oil pan you using?
Old Dec 28, 2011 | 10:46 PM
  #20
Jon, you are really moving fast with the fabrication!! Again, the setup has already exceeded my high expectations
I am going to run a Tial 44mm or 50mm wastegate. Also, I have the Canton pan for LT1 F-bodies on my car.
Thanks again!!!
Old Dec 28, 2011 | 11:16 PM
  #21
RealQuick's Avatar
Thanks again!!!
JGS 50mm gate and call it a day. Plus i have one I can use for mockup
Old Dec 29, 2011 | 09:09 PM
  #22
RealQuick's Avatar
Old Dec 29, 2011 | 09:13 PM
  #23
RealQuick's Avatar
Clearance of short downpipe piece next to pass side k member:
Clearance of DP near starter. I had to route it here due to jason running a canton oil pan.
Clearance of DP under accessory bracket
O2 sensor pass side
driver's O2 on crossover
Clearance between DP and crossover
DP under pass side motor mount
Old Dec 30, 2011 | 09:18 AM
  #24
Jon,
I can't tell you (again) how happy I am with how it turned out You've exceeded my already high expectations!! Every setup I've looked into (or owned) involved sacrificing something. Aside from the A/C (which I didn't want or need), I can truly say that I have not had to sacrifice anything with this setup
Old Dec 30, 2011 | 12:09 PM
  #25
DirtyDaveW's Avatar
Man, that is beautiful! Great job Jon and this kit should be a great producer for you Jason!
Old Dec 31, 2011 | 09:25 PM
  #26
RealQuick's Avatar
Thanks guys. Twin feed pipes for the 50mm wastegate. You can see the start of the dump pipe for the downpipe
Old Jan 1, 2012 | 08:59 PM
  #27
RealQuick's Avatar
downpipes welded
File Type: jpg
Old Jan 1, 2012 | 11:42 PM
  #28
Jon, this setup is looking crazier by the day! I just tried sending you a PM, but your box is full.
I can't believe how this is turning out. You have gone WAY above and beyond for me on this!!
Old Jan 1, 2012 | 11:47 PM
  #29
Geoff Chadwick's Avatar
Holy cow and I thought my routing was intense!
Just as a thought, would going to the gear-reduction LT4 starter get a little more clearance in there?
Old Jan 2, 2012 | 09:23 AM
  #30
RealQuick's Avatar
Hey Geoff, yeah the LT4 starter should help with clearance. What's up with your car?
