Turbo in...:)
Old Oct 27, 2008 | 10:20 PM
jay_rich's Avatar
Turbo in...:)
Well About time I am finally dreaming about doing a turbo swap and I am underway!
And well LS1 calipers too!
I just got it in the mail and need to polish/paint it.
Its a Garret/AiResearch TH08A64
T6 Flange
5.125 Downpipe
.96A/R Hot Side
74mm turbine
So far I have..
Turbo
Intercooler
Boost Gauge
some random piping
Feed/Drain lines
Jay
Old Oct 29, 2008 | 09:53 AM
RealQuick's Avatar
Nice. Any reason you chose that turbo?
Old Oct 29, 2008 | 10:33 AM
Tricked-Out-Toy's Avatar
what are you doing for the hot side? Making a log setup like mine should be real easy it only took me about two weekends to get everything mocked up. The long part for me was welding and smoothing. (im going for the smooth, all one piece look)
Old Oct 29, 2008 | 11:41 AM
jay_rich's Avatar
I chose it because I got a really nice deal on it and im on a budgit, bought too many toys this year(the 383 and a 2000 gsxr 750)
Also bc it can be upgraded to a 88mm wheel.
Also I plan on building headers, not sur eon 1 5/8 or 1 3/4.
I am copying the Ohio Forced Induction LS1 Kit kinda.
Jay
Old Oct 29, 2008 | 05:35 PM
boosted-lt1's Avatar
Jay,
1 5/8 will probably be more than adequate for a small block V8 turbo. When I asked Jose, his response was that many 1 5/8 setups are making well north of 700-800+ to the tire.
Estimated change in kinetic energy based on change in diameter from 1 5/8 to 1 3/4 is about 45% reduction. This might indicate that spool time would increase with the larger primary to some degree. But I think overall this is not a huge factor on a V8 and the larger primary will support more power if you need it to. Try to keep as much heat in the exhaust portion driving the turbine as you can either way. Coated or heat wrapped, distance to turbo and so on.
EDIT: Cool car. Reminds me of a cartoon I watched as a kid - MASK - where a red third gen could fly.
-Scott.
Old Oct 30, 2008 | 03:05 PM
ya, the reading ive done lead me down the 1 5/8" path. I wanted the quickest spool and my goal was 700 so there shouldnt any problem getting that with 1-5/8". look at the guys make 1000+ with cast log manifolds.... 1-3/4 would be overkill and hurt your spool time. Its a balancing act between bakc pressure and velocity.....
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
