Tuning after turbo install
Re: Tuning after turbo install
Originally Posted by rskrause
The Innovate works well, I haven't used the other one. IMHO you need a WB to tune a blower car.
Rich
Rich
Do I need one per bank, or can I assume both banks are performing equally by stock O2 sensor readings?
If you're gonna tune it yourself, you're gonna need the WB. If you get HPTuners, get the enhanced i/o, and an Innovate LC-1. You'll be able to log the afr at all times, it's a pretty sweet setup. I actually have the LM-1, but from I heard you could use the LC-1 and it's cheaper.
Originally Posted by ramair96ws6
hptuners would work great if it was an LS1
Are wideband O2 sensors threaded the same as OEMs? Or am I going to have to remove one of my headers and weld a bung onto it... that'll be a blast.
HA!! Way to go me. Damn, I wasted all of that time typing a bunch of stuff you can't use!
Anyway, I had to weld in a bung for my narrowband. I put mine in the y-pipe. Now I'm gonna stop typing...
In your Y-pipe, with cats or no cats?
Originally Posted by evilundisguised
Yah I was looking at their website, not finding anything to do with LT1s...
IfAnother thing to look is if you have never tuned do you trust yourself with the health of your motor. If you have done any searching on this board you will see that the stock LT1 motor is no lover of the boost it has to much of a glass jaw rotating assembly. It only takes one oops in the tune and its rebuild time.
-Chris
