Trick Flow Heads?
Old Jan 26, 2004 | 09:32 AM
NiteRyda's Avatar
Trick Flow Heads?
I was looking in the new Summitt book and saw the Trick Flow Heads for the Lt1( Blown, Stroked, or juiced). Do you guys think these are some good heads for a stock bottom end with 8# boost. Also what will be a good cam to go with this setup. I have my pcm programmed for a stock engine set with throttlebody and longtube headers and bigger 36 lbs injectors. What will i need to do to my pcm for the heads and cam change if anything. The tunning is a OBD-1 form PCMFORLESS.
P.S. the heads are 195cc intake, 75cc exhaust, 64cc combustion.
The cam in mind is a comp cam 306.
Will these heads lower the Compression Ratio any?
My mods are at the bottom of the post.
Old Jan 26, 2004 | 11:18 AM
RealQuick's Avatar
Re: Trick Flow Heads?
Those heads should work out great for a bolt-on. I am concerned about your cam choice though. Your gonna bleed of cylinder pressure with all the overlap. Maybe you should look into the 224/236 w/114lsa.
Old Jan 26, 2004 | 11:32 AM
rskrause's Avatar
Moderator
Re: Re: Trick Flow Heads?
I also would urge you to consider a different cam. The CC306 is far from an optimal cam for what you are describing.
Rich Krause
Old Jan 26, 2004 | 11:41 AM
NiteRyda's Avatar
Thank's for the Reply!
Are their some other cams that would work for my application!
Also when i am doing the cam and head change are their any other things that need to be done when changes are being done!
Old Jan 26, 2004 | 03:20 PM
NiteRyda's Avatar
Are their anymore people that can advise on a cam for a stock bottom with heads for this application?
Old Jan 26, 2004 | 03:23 PM
Sean94Z's Avatar
Comp Cams makes one .. 218/230 114 LSA .495/.515 (I think those are the specs) Look on thunder racing's web-site and racenet.net .. They both carry it I believe
--Sean
Old Jan 28, 2004 | 01:23 PM
SloLt1Z's Avatar
I would get a 224/236. I got mine from www.cmotorsports.com
Old Jan 30, 2004 | 05:00 AM
96 WS6's Avatar
In general on a blown car you want at least 114 lobe separation angle and about 10-12 degrees more exhaust duration than intake. cc306 is an extremely poor choice as a blower cam and is more suited to natuarally aspirated engines.
I would recommend the 224/236 (there are a couple grinds that are good), the 227/239, or the cc305 on 114 lsa.
Old Jan 30, 2004 | 12:56 PM
NiteRyda's Avatar
Extra Tuning
Will i need to have my PCM programed again for the heads and cam change, and will i have to port my throttlebody.
Old Jan 30, 2004 | 03:23 PM
Wild1's Avatar
Since you are doing your purchasing and planning... don't forget about your ignition and fuel system. Make sure they are in spec... injectors, pump, ign. module, etc...
I noticed you have the 36# injectors, but I'm not sure if that will be enough for your desired horsepower level. May need 42# injectors...
BinkZ28
Apr 20, 2015 09:10 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
