torque converter for twin turbo
Old Aug 14, 2005 | 03:39 PM
  #16
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Re: torque converter for twin turbo
Another vote for Neal Chance. We use one in our turbo/LS1 shop car that currently makes about 875rwhp.
Old Aug 15, 2005 | 10:28 PM
  #17
arnie's Avatar
Originally Posted by rskrause
I doubt PI has anything beefy enough.
Rich, how many discs in the clutch are you referring to?
Originally Posted by Brady
NOT! I've been there with them. I sent my converter back three time to get it tightened up, they eventually told me that they couldn't make it tight enough.
Brady, I'll ask you the same question. What number of discs comprised the clutch, in the convertor you are referring to?
Old Aug 15, 2005 | 11:34 PM
  #18
rskrause's Avatar
Moderator
Originally Posted by arnie
Rich, how many discs in the clutch are you referring to?Brady, I'll ask you the same question. What number of discs comprised the clutch, in the convertor you are referring to?
Arnie: my doubt wrt PI making the right converter for this app. was based simply on the observation that I have not heard of or seen any super hi-po cars running them They could no doubt make a suitable converter if they chose to, just that AFAIK they do not.
Rich
Old Aug 16, 2005 | 06:41 AM
  #19
arnie's Avatar
They could no doubt make a suitable converter if they chose to...
They could, or they already do? What I was getting at Rich, was to find out, if those that have issues, are choosing the appropriate convertor. They have several, including the 5 disc setup. Would still like to know what clutch setup Brady was having issues with. Now if issues are in the convertor stall itself, and have little to do with the lockup, then it is mute.
Old Aug 16, 2005 | 09:07 AM
  #20
rskrause's Avatar
Moderator
When I did the automatic thing, I looked into a lockup setup. No one, including PI, would even claim that their lockup converter would stand up to 1,000+ hp. PI did say that their 5-disc setup might be up to the job, but it didn't sound like they had even tested on something as powerful and heavy as a 4,000lb car with 1,000+hp.
We are in a situation now where engine builders are out ahead of tranny builders. As far as automatics go, the PG is the easiest tranny out there to build up handle mega hp, even in a heavy car. But a PG with the needed loose converter in a car intended for some street as well as strip duty would be a complete PITA. A TH400 can be built strong enough as well. But the lack of OD is still an issue as is the lack of a lockup converter solution.
As far as manny trannys go, a fully built up T56 by G-force is probably the best solution. Costs about $5K and to that you must add add another $1K+ for a clutch. If I were still after a street/strip solution I would either do that or try the Lenco route that I have posted about. The Lenco would be megabucks, however.
The best auto option might be a built 4L80E. If you do a search you can follow the path taken to get there. Or, one could go the TH400+GV OD route. Expensive and heavy, but it would do the trick.
Rich
Old Aug 16, 2005 | 09:20 AM
  #21
Cody's Avatar
does anyone know anything about Trans-Kings steel stator converters
LeftoverChinese
Jan 14, 2024 03:03 PM
Fastbird93
Apr 9, 2016 07:01 PM
dboone2172
May 16, 2015 07:45 PM
veryslowfbody
Aug 22, 2002 04:31 PM
Brady
Jul 29, 2002 10:30 PM
