tial wastegate help.
Old Jan 4, 2004 | 08:53 PM
2turboz28's Avatar
i have a turbo setup on my car right now. its a t72 ball bearing turbonetics turbo. i am also running a tial 38mm wastegate on it and i have it installed in the exhaust properly. i was wondering where the vacuum line goes. right now i have it on the side of the diaphragm and the top is left open (per tial tech support). i think that this is the wrong way or at least the top needs too be blocked off.any help is greatly appreciated.
thanks,
matt
Old Jan 5, 2004 | 12:14 AM
y2khawk's Avatar
I'd think that Tial might know their own gate
Top port open, or to a boost controller it you got one.
If you plug it, the gate won't open.
Old Jan 5, 2004 | 10:44 AM
2turboz28's Avatar
they said that the boost controller line should go too the nipple on the side. that didnt make too much sense too me but the car is only makin the boost ragulated too the spring. tial told me that the top nipple is for an electric boost controler only. either way if you have one hooked up in your car, lemme no where the vacuum lines are goin.
Old Jan 5, 2004 | 10:56 AM
Tiago's Avatar
harlan's top line is connected I can see it in the pics lol...
Old Jan 5, 2004 | 01:51 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
it sounds like you do NOT have a boost controller? if you do NOT, leave the top open, and you should get boost ~spring pressure.
Old Jan 5, 2004 | 02:00 PM
2turboz28's Avatar
i have a turbonetics mbc on the car. i jsut need too no where it goes too. there are 2 vacuum fittings and i have heard that i have too hook up either the top or side. i need too no where the line from the mbc goes. and what do i do with the other vacuum line.
thanks,
matt
Old Jan 5, 2004 | 02:32 PM
Tiago's Avatar
lol
ther must be a line from the intake manifold or some vaccum source that feeds into thte wastegate. Thats how it registers boost and knows when to release. So that line should be intercepted by teh MBC so it can create the pressure differential in the vaccum signal, causing more boost.
Old Jan 5, 2004 | 03:31 PM
2turboz28's Avatar
ok, i have a dedicated vacuum line going too the mbc from the intake. that isnt the problem. i need too no where the line after the mbc goes on the tial gate. is it the top or side fitting? and also what does the fitting that isnt used with the mbc go too. do i leave it open too the air like i have heard? or do i have too cap it?
that was what i was wondering. sorry i am only asking because i have never used a tial wastegate and no directions came with it and none are avail. on the site.
thanks,
matt
Kinglouui
May 26, 2016 11:05 AM
David Dempsey
Mar 12, 2016 12:42 AM
truecontr3
Oct 11, 2015 09:30 AM
surreybrad
Sep 29, 2015 09:00 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
