Threw a blower belt today, anyone know how install a new one with a SDCE tensioner?
Old Jun 11, 2007 | 08:48 PM
  #16
Ponyhntr's Avatar
Originally Posted by Fastbird93
Getting it overnighted?? How much did the new belt run?
ATI sells the 12 rib belts for $84 plus freight. If you order through a dealer you can get a better price than that.
Old Jun 11, 2007 | 09:01 PM
  #17
CALL911's Avatar
Should have the new belt on sometime in the afternoon tomorrow, assuming it doesn't rain, and everything is still running good, I'll be trying my luck at the track.
Old Jun 11, 2007 | 09:16 PM
  #18
Fastbird93's Avatar
GIT-R-DONE!!!!! I'm dying to see what you can do. Remember -- Hard launch and I'm going to kick you in the junk if you baby those shifts. You better call me with a low 11 or high 10 tomorrow night.
Old Jun 11, 2007 | 09:44 PM
  #19
Ponyhntr's Avatar
It better be a 10, or I'm going to
Old Jun 11, 2007 | 09:45 PM
  #20
Ponyhntr's Avatar
Thanks to Ponyhntr, I will be running the 12 rib 42" belt I need without trying to work something else that will make it happen. Thanks man!
BTW, if everything goes right, I'll have track video tomarrow night.
No problem man, glad I could help!
Old Jun 11, 2007 | 10:08 PM
  #21
Fastbird93's Avatar
The car has it in it, no doubt about that. I think a 10 is pushing it for a first time out with the new setup though, no matter how much street driving he's got under it.
Old Jun 12, 2007 | 07:15 AM
  #22
CALL911's Avatar
The forecast is calling for thunderstorms thisafternoon So, you might not hear anything. If it doesn't happen today, I might try again on Thursday (although they are calling for a similar forecast then as well ). Sooner or later it will have a track run. With the traction I am getting just on the DR's, I don't see how I can't run a good time unless the car breaks .
Old Jun 12, 2007 | 10:43 AM
  #23
xxsaint69x's Avatar
Id say you will be able to get really close to 10s..i ran a 11.6 @ 131 (that was right at 600rwhp) Full street trim (3800+lbs with me in it) on nittos drs that didnt hook for ****. 2.2s 60s eheh.
Old Jun 12, 2007 | 11:54 AM
  #24
CALL911's Avatar
I ran 11.8 @118 when I was only at 420 RWHP, so I would hope that the additional 194 RWHP should get me more than .8 in the quarter. Time will tell
Old Jun 12, 2007 | 06:36 PM
  #25
mehoffz24's Avatar
call 911. if you dont mind me asking, where are you located in jersey?
do you usually run at atco or englishtown? i would really like to see your car. by the way check my sig, my car weighs in at 3710 with me. so you should be running faster than me with that power!!! good luck
Old Jun 12, 2007 | 09:25 PM
  #26
CALL911's Avatar
I am in central Jersey (Burlington County) at McGuire AFB. Not sure if you are on the NJFBOA board or not, but my username is the same on there. I usually go to Atco. I might be going Thursday.
I just now got done with 4 hours worth of the blower belt install (thanks again for the help Josh ), I think its running good, but I won't be able to tell for a while. It is downpouring right now. I tried taking it for a test spin, but as soon as it saw 8#'s of boost the back end slipped and slidded all over the place at 90 MPH, so I thought I would hold off until things dry off.
The only issue is, I broke the coolant temperature sensor in the waterpump during the install. After a quick run to AutoZone, I replaced it with a new one, but the new one (even though it is really tightened into the waterpump as far as it will go) rubs a little on my tensioner . It just barely rubs on the edge of it, and when giving the car gas, the tensioner goes away from the sensor, but I have a feeling sooner or later it will destroy my new sensor .
Thanks again to all for all your help. I'll let everyone know in a couple days if its 100%.
Old Jun 12, 2007 | 10:37 PM
  #27
ZBLKHELLRZR's Avatar
Ben glad you got that fixed. I hate you. J/K. Nah I hate I can't just go the store down the street and pick up a part like you can but instead I have to wait 2 wks.
I'd think you guys w/ these 383's and big heads would be putting down bigger numbers HP wise but hell your mph's are nice! So those dyno numbers don't mean squat.
I've got a date w/ the dyno the 25th! Got to find me a trailer before then or limp it 2 hrs to the location. I wonder if I'll hit the 22psi it's pullied for?
Old Jun 13, 2007 | 06:17 AM
  #28
CALL911's Avatar
Silas your car (as well as Fastbirds, and Ponyhntrs) ought to do a bit more power than mine on the dyno. Just be patient with it. Keep in mind mine has been running since last year, and I am just now working out the final bugs.
Just ran the car thismorning. Seems to be solid as it was before! The sensor is close, but still okay as of now. Asuming the weather and my schedule is good, Thursday will be a track day!
Old Jun 13, 2007 | 06:40 AM
  #29
Fastbird93's Avatar
21.5 PSI is my prediction! Actually, results from your car is probably going to be the make or break for me sticking with the D-1SC or not. I'm VERY interested to see what yours does.
SpeedJunkee
Jan 27, 2015 10:02 PM
Snoman73
Nov 17, 2014 07:22 PM
1LEThumper
Jul 14, 2003 12:45 PM
StngStlkr
Sep 6, 2002 05:47 PM
