thoughts on my twin turbo motor
just thought i would toss out to the group the build i have in progress.
Block: Dart lil' M
Main caps: splayed steel
Cap Fasteners: arp studs for center, bolts for outer
Bore: 4.125
Crank: Callies 4340 knife edged 3.48" stroke
Rods: BME 6"
Pistons: Custom Diamond, tooled steel pins
Cam: custom turbo grind... 26x/26x .600/.600 lift with 1.5:1 RR
Heads: Dart Pro 1 230cc/72cc chamber, mild port 2.08,1.62 valves
Intake: Single plane, ported and port matched to heads
TB: Wilson 90mm with GM electronics on a sheet metal elbow
Injectors: 96lbs/hr
EFI: DFI Gen VII with Closed Loop WB02, full sequential
Distributor: Accel V8 Dual Hall-effect (Cam/Crank)
Exhaust Headers: custom 321 stainless twin turbo headers
Turbos: Twin PT-67 P Trims
Wastegates: Twin TiAL 38mm wastegates
N2O: 200 wet shot
Block: Dart lil' M
Bore: 4.125
Rods: BME 6"
Injectors: 96lbs/hr
N2O: 200 wet shot
Block: Dart lil' M
Bore: 4.125
Rods: BME 6"
Injectors: 96lbs/hr
N2O: 200 wet shot
Block: Dart lil' M
Bore: 4.125
Rods: BME 6"
Injectors: 96lbs/hr
N2O: 200 wet shot
just a little awd s10. shooting for mid 8s on 315/17 street tires. 4link w/ coil overs in the back, coil overs up front. chassis is certified for 8.50.
and i do plan on driving it quite a bit on the street. should be fun
From: I reached back like a pimp and smacked that LS1....
Looks good, but personally I would run a cam with about 25 degrees less duration @.050 if it's going to be driven on the street.
(You won't need that much cam or the nitrous to meet your goals).
i will post up some pics once i get things cleaned up and in order a bit.
Keep in mind that I know absolutely nothing about auto trannys, my solution would be (as always) use a manual
LT1runner
33
Jul 24, 2002 01:19 PM
ced8
Jun 24, 2002 11:11 AM
