To those of you running 12+psi on an lt1
Ok heres my problem I ordered a turbo system with GTS76 turbo and I am only runing 8psi but I want to run from 12-13 or more psi so I'll be running about 600hp but I know it will kill my stock engine I have big enough injectors and fuel pump and I have a nelson performance pcm but I dont know how much I can slow the timing but I need to know like what crank,cam,pistons,heads.ect to use so I can run that much boost and If you could tell me what ones and where to buy them it would be a big help cuz I have been unsucessful in finding them and also how much horsepower is a stock crank good for its 450 isn't it? and how much will my six speed handle?
so if someone could help me out I would be very thankful
I'm running 11.5 psi on my stock impala bottom end LT1 right now. It's not going to last long though. When it blows, I'm just going to go with some ported GM LT1 heads, forged pistons, stock rods, and a cast 3.75" stroke crank. It should be strong enough to handle my goal of ~525rwhp at around 6200 RPM.
oldschool
Feb 9, 2016 09:21 PM
Camaro90RS
Jul 23, 2002 07:57 AM
