thinkin bout goin to the ltcc setup! anyone heard anything bad/failures?
Old Nov 10, 2009 | 01:27 PM
  #16
ramair96ws6's Avatar
Originally Posted by jsetzer
My vote still says its an expensive system that still relies on the opti.
I like solutions that eliminate it.
Why? as long as the high voltage section is removed it has been proven to be a reliable system. The LTCC isnt that exspensive, its plug and play, and works perfect.
What was your cost to remove the opti?
Old Nov 10, 2009 | 01:36 PM
  #17
jsetzer's Avatar
Cost to remove was right about $300 for me. But it wasn't plug and play.
The ltcc is better than the opti for sure - but I have had just as many failures from the sensor as the cap/rotor. I don't trust the thing lol.
The one that converts to ls style pickups and computer is cool too - but very pricey.
Old Nov 10, 2009 | 02:27 PM
  #18
What did you do, put a low profile distributor on it?
Old Nov 10, 2009 | 03:35 PM
  #19
The SRZ's Avatar
Something like this? http://www.eficonnection.com/eficonnection/default.aspx
Old Nov 10, 2009 | 08:06 PM
  #20
jay_rich's Avatar
he runs a ford coil pack system
Jay
Old Nov 11, 2009 | 09:13 AM
  #21
jsetzer's Avatar
Running coil pack per cyl now - but still the same setup pretty much minus the Ford EDIS module. Still waste spark, but doesn't seem to be an issue.
MS3 will support sequential injection and coil on plug straight out of the box with no mods. 6 can be full sequential right now, theres just not enough outputs to do it with 8.
Old Nov 11, 2009 | 09:43 AM
  #22
Unless you used nothing but used parts to include the MS3 it is hard for me to believe this was done for 300.00, could we see some pics of the ford system on the car?
Steve
Old Nov 11, 2009 | 10:44 AM
  #23
David94TA's Avatar
Ramair96ws6, that is a great looking setup. How did you mount the coils under the cowl? Do you have any pictures of the mounting brackets?
Old Nov 11, 2009 | 12:22 PM
  #24
I bought this kit from thunder racing. polished the end parts and powder coated the rest black.
http://www.thunderracing.com/catalog...vid=3&pcid=273
Old Nov 11, 2009 | 01:52 PM
  #25
97WS6SCharged's Avatar
Steve
The most expensive part of that ignition setup is probably the coil pack itself which is about $100.
Megasquirt is pretty nifty. I'm about to be running one on a small block S10 very shortly.
http://www.megamanual.com/ms2/EDIS.htm
Oh, and Bob said the new harness was $150.
Old Nov 11, 2009 | 02:01 PM
  #26
jsetzer's Avatar
Go to a salvage yard and pull off 2 edis coils for $10. They are 4 post coils, with 2 coils in each pack. So 2 posts per coil really.
It "can" be done cheap. I can pull these of of any Ford in the 90s - The ltcc is a bit more of a custom job so I doubt you find them as easy. FYI the stock 200k mile Ford coils worked fine for me up to about 500hp and then they were not enough. I am now running some screaming demons which were $90ish total and seem to do the job. I would like to go to ls2 coils but have no reason to spend the money on them now.
Old Nov 13, 2009 | 07:23 PM
  #27
96SilverRam's Avatar
I suppose it would not be fair unless I throw in a pic or two of the Delteq setup
Old Dec 23, 2009 | 06:18 PM
  #28
ponyackn's Avatar
Is there any issue running the LTCC with a supercharged setup? I heard that there might be, although, I can't imagine what complications would arise. I must ask though, if I were to use the LTCC, how would it change the wire routing of an MSD 6 box or could I run it at all?
Old Dec 23, 2009 | 09:20 PM
  #29
DirtyDaveW's Avatar
The LTCC will run fine with any power adder.
No, you won't be able to run the MSD box with the LTCC since the MSD 6 is used to control ONE coil. MSD does have the multispark discharge version of the LSx coils but they are pricey.
Old Dec 25, 2009 | 05:11 PM
  #30
96PTKZ28's Avatar
Thats why you should buy a DYNASPARK GEN III and you will not have anymore classic opti issues. They arent cheap but much better than a OEM optispark!
