Switching to ms2 extra
Old Mar 27, 2009 | 11:17 PM
  #16
jay_rich's Avatar
Ill probably switch to this next year when I run a distributor. Since I have a third gen I have all the room for a distributor . Possibly go to a single plane too.
Jay
Old Mar 30, 2009 | 09:10 AM
  #17
jsetzer's Avatar
I thought a lot about a dual synch setup, but decided things would be a good bit cheaper with coil packs.
Old Mar 30, 2009 | 11:18 AM
  #18
jetjoe's Avatar
Are you still using the EDIS8 coil packs or did you switch to individual LS coils?
Old Mar 30, 2009 | 12:50 PM
  #19
jsetzer's Avatar
EDIS coil packs - Unless you run the sequencer you are going to get wastespark even with the ls1 coil packs - doesn't bother me either way, just cheaper with the ford style.
Old Apr 21, 2009 | 06:37 PM
  #20
jetjoe's Avatar
Do you have any pics of your crank trigger wheel installation? I assume you are using a 36-1 with the EDIS.
I was also reading on DIYautotune that the low res output of the opti can be used to trigger a single coil ignition. I wonder if there is a way to use that to run a wasted spark ignition?
Old Apr 22, 2009 | 09:31 AM
  #21
jsetzer's Avatar
Yes you could use the low res pulse and just the edis coil packs without a edis8 module. Thats assuming there is a missing tooth in there, if not you could just close one of the gaps in the disk. The sensor was always my problem with the opti, so I avoid it like the plauge. If I were to switch or do it again I would use the obd2 crank position sensor. If you don't have a 96/97 car you just need the ring, sensor, obd2 timing cover, 96-97 crank hub.
I don't have any good pics, but the motor is coming out soon because I popped a head gasket. I'll get pics of the trigger then. Its just the biggest wheen from DIY with some angle iron welded together for a mount. Mount bolts to the block with 2 open bolt holes.
Ericksd
Jan 20, 2016 06:07 PM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
