supercharged
Old Nov 16, 2003 | 04:27 AM
dmoss69's Avatar
supercharged
I seriously thinking jumping onboard with the forced induction. My question, how hard is it to obtain 500 to 600 rwhp? I have my 95 that is naturally aspirated, but I'm about to build another one. My 95 is strong, but I want something scary.
I have another 95 that the engine is knocking, so now is the time to rebuild. I see where people is putting down 375 rwhp, but I'm doing that on what I have now. Like I stated above, I want 500 to 600 rwhp and terrorize the streets.
D Moss
Thank God for this website!!!
Old Nov 16, 2003 | 07:49 AM
steve10358's Avatar
3rd Gen Tech Moderator
Good heads, Lotsa boost, and dyno assisted tuning by someone who knows their stuff.
Old Nov 16, 2003 | 01:00 PM
Mikael's Avatar
Turbo or super? A strong engine, nice cam, and enough turbo boost will put you there no problem. If its going to be super, i think you'll have to do a full heads/cam.
Old Nov 16, 2003 | 02:19 PM
Chris B's Avatar
A 383 with a s-trim will get you there easily with a minimum of hassle. You should decide what hp you want though - there will be a difference between what you need for 500 vs. 600rwhp.
Chris
Old Nov 16, 2003 | 08:01 PM
dmoss69's Avatar
turbo
I'm seriously thinking about the STS Turbo kit. Man that think seems awesome. I'm wondering what kind of power would that thing put out if it had ported heads, headers, and 3angle valvejob and nasty camshaft.
I'm thinking about getting a GP on this. What do yall think?
dyno killer?
D Moss
Old Nov 16, 2003 | 08:10 PM
rskrause's Avatar
Moderator
Turbo's have a lot of potential advantages. However, there are a lot more good running SC cars than turbo cars out there, which should tell you something.
As Steve said, there is no secret at this point to building a SC setup in the hp range you are considering. But as Chris has said, you will be in a different ballpark at the 600hp level vs. 500.
In either case, don't forget to budget the cost of the supporting components you will need, especially a rear end if you plan to race it with slicks and an upgraded tranny and converter if you are running a 4L60E or clutch for an M6.
Rich Krause
Old Nov 16, 2003 | 08:14 PM
Rival's Avatar
There are many more supercharged f bodies. 9 out of 10. It is going to be less expensive and easier to do. Any car that is over 450rwhp on the street is too fast. So the if you looking for 5-600rwhp, 500 is going to be much easier to make. It is going to take a s-trim/p600 or larger at 12psi, good heads and a blower cam. The tuning is also very important.
Old Nov 16, 2003 | 08:18 PM
dmoss69's Avatar
turbo
Well for the money, from what I have seen the STS is making awesome power with the stock trimings. Maybe I'm being mislead, but I'm thinking the STS would be cheaper to build than with a SC.
Please scold me if I'm wrong.
D Moss
Old Nov 16, 2003 | 08:24 PM
rskrause's Avatar
Moderator
Re: turbo
D Moss
I am not sure about the exact costs, but besides the cost of the blower, getting everything working right can be every bit as expensive. That's what I am alluding to when I pointed out that there are many, many more SC cars out there. The knowledge wrt setup and tuning is much more prevalent, which can make the whole experience more pleasant and less costly.
Anyway, 500hp isn't ever cheap and 600hp gets downright expensive. With each increment in performance, the cost seem to increase geometrically.
Rich Krause
Old Nov 16, 2003 | 08:53 PM
engineermike's Avatar
If I were to start over, I'd get a PTK Turbo kit instead of the Vortech T-trim/Aftercooler. As RKrause stated, turbo's, in general, are better than superchargers. They produce about the same peak hp, but with far more low and midrange torque.
Costs?
Vortech T-trim + Aftercooler + Hooker LT's and hardware = $5900
PTK Turbo Kit (intercooler included, headers included) = $5000
The STS turbo is a good idea and certainly has advantages as far as ease of installation and access to the engine. But, with the turbo that far from the engine, the exhaust cools and loses much of its energy before reaching the turbo. This means that the turbo can't build boost until the exhaust system heats up.
The PTK turbo looks more like an OEM set-up like the '86/'87 Buicks.
Now that I think about it, anyone want to buy a T-trim/Aftercooler/Hooker LT's for $5000?
Mike
Old Nov 17, 2003 | 07:21 AM
96 WS6's Avatar
I origially had a turbo tech kit I traded for my s-trim + some goodies. The S-trim has been much easier (i'm assuming), and it's a a proven reliable kit with a ton of support on the board and it will get me to my goal of 500 rwhp. You want easy, go blower. You got money, time, knowledge and most importantly - GOBS of low end torque, go turbo.
Old Nov 17, 2003 | 07:14 PM
dmoss69's Avatar
I was searching around, and I found out that turbos aren't really that expensive. It's the kits that are out of this world prices. Of course, there's the agravation factor and time, but thats where the gratitude comes from on my end. I'm seriously thinking about a turbo on something that I own.
D Moss
Old Nov 18, 2003 | 12:12 AM
LWM's Avatar
LWM
Chris
Yup, agreed, 3 pulls on the wide band dyno, found that it was pretty much "tuned" with the stock fuel and spark advance maps still in place. The recipe I used, after reading the board and asking the questions, worked, worked first time, it should be considered a "cook book" recipe for 500+ hp at the wheels. Details in web page.
Rich Krause
rskrause
What Rich said ... a S/C car in the 500hp range can be done at a reasonable price ... if you go turbo ... be ready to call the rape squad after you see what they do to your wallet ... it won't stop there if you really got the "bug" ... and strapping a pie plate to your a$$ won't stop the pain, it will only slow it down ....
Deal with it ... the dark side is waiting ... you won't be dissapointed.
Hope this helps
LWM
Old Nov 23, 2003 | 10:41 AM
hurricaine418's Avatar
sts turbo
is sts a brand of turbo? im looking for one also. any websites with sts on it? thanx
Old Nov 23, 2003 | 05:25 PM
dmoss69's Avatar
from what I have seen and heard lately, the $3000 kit from STS won't give you the 600 rwtq and 500rwhp.
You have to spend extra money for the water-methenol solution kit.
Then put dished pistons in the car.
Just information, thats all.
D Moss
Hal Fisher
Sep 30, 2015 09:03 PM
HAWG
Sep 25, 2015 11:41 AM
DelSoto
Sep 19, 2015 05:31 AM
rideordie
Sep 7, 2015 08:22 AM
