NGK TR6 spark plug gap with ATI procharger
I am in the process of putting my motor back in and bolting on my ATI Pro-Charger D1-SC. Anyone know what gap I should use with the NGK TR6s? I will be running 12lbs of boost on the street with 94 and 14lbs at the track with 110. I also have an MSD 6AL, other mods listed in profile. Thanks!
hey orion, I'll be running a very similar setup to you: ls6 stage two heads, and a d1SC as well. I got a ten pound pulley to run on it. My question to you is. Are you gonna run 14 psi with stock CR/bottom end?
racecarz28
Mar 30, 2015 09:55 PM
