super charge 383/355?
Old Feb 16, 2003 | 10:26 AM
detska's Avatar
any body have a sup'd 383 or 355 lt1?
did you run a baseline?
what kind of hp did the engine make after the comp was lowered but before the blower was put on?
Thanks in advance.
Old Feb 16, 2003 | 01:52 PM
You would be a lot more likely to get a lot of answers to this in the "Forced Induction". Moving it there.....
Old Feb 16, 2003 | 02:12 PM
TimbrSS's Avatar
I believe you are asking for the effects of compression ratio on a motor. I think the common assumption is about 5% loss per point dropped in compression motor. ie. 400 hp at 10.5:1 would be about 380 at 8.5:1, all other factors the same.
Old Feb 16, 2003 | 03:16 PM
rskrause's Avatar
Moderator
Lowering the CR on a blower motor allows you to run more boost and make more hp. In any case, the hp difference in this range is at most 2% per point of compression (all else bieng equal).
Rich Krause
Old Feb 16, 2003 | 04:46 PM
TimbrSS's Avatar
Rich Krause
i guess i was being a little generous.
Old Feb 16, 2003 | 07:31 PM
detska's Avatar
thank you guys!
G-BODYT56
Jan 14, 2022 11:14 PM
RUENUF
Mar 13, 2016 03:37 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Daluchman1974
Sep 11, 2015 06:12 AM
