STS install issues or tricks
Old Jan 3, 2008 | 01:17 PM
  #31
branland's Avatar
Originally Posted by vipercrt
Well, I had the same issue with the bov pipe fitting too, so I took a hach saw to it and shortened it underneather the car alittle. The other issue might just need some tweaking, but I have used all the proper bolts so I am not sure. Does the bov need a pressue line going to a vacuum line in the manifold, or does it operate correctly without that valve. I just welded the flange and bolted the bov off, and when the car is in running condition it appears that it works fine.
I am also having an issue with some leaking at the oil fill cap (return line). Mine appears to be the actual cap not seating tight, not the little brass fitting but I will recheck when I get it running again. Thanks for the info, and if you could expand on the oil seperater and catch thing you were talking about I would appreciate it.
I have the BOV line spliced into the brake line. I also had a problem with the oil cap not catching enough threads. I’ll take some pictures of everything when I get home tonight and post them.
Old Jan 3, 2008 | 02:39 PM
  #32
vipercrt's Avatar
Cool, Thanks
Old Jan 3, 2008 | 10:16 PM
  #33
branland's Avatar
The BOV line is spliced into the connection from the brake booster and the manifold. Fig_4
The oil cap can be turned on the fitting to make it tighter Fig_5
There is an enormous amount of info on catchcans and air / oil separators in this forum. After reading through several threads here is what I choose to do:
I bought a, catchcan capped off the line from the throttle body, and ran a line from the passenger side valve cover to the catch. ( Fig_1, Fig_2, Fig_3, Fig_6) The catch can is mounted behind the headlight since this is a high pressure zone. Under boost, the speed of the car will increase, causing more air to pass by the filter creating a low pressure zone in the tank. Although it’s not as good as a vacuum pump, it should be able to draw the blow by into the tank.
The air / oil separator ( Fig_3) is between the PCV valve and the intake manifold to keep oil from being drawn back into the manifold. If I had it to do over again I would have gotten the can with dual connections and spliced the connection from the intake manifold and added a few check valves. The way it’s set up now, under boost, blow by gets into the air oil separator.
BinkZ28
Apr 20, 2015 09:10 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
edman
Jan 22, 2015 02:45 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
