Strength of rod bolts?
How strong are the stock rod bolts. Are they a major weak point of the bottom end? I know the pistons are the # 1 weak spot of the bottom end, but how do the rod bolts hold up to the power…
Re: Strength of rod bolts?
The power isn't really the problem, it's the RPM where the power is made. FWIW, if you're going to spend all kinds of money on a motor and FI setup, are you really willing to trust the stock rod bolts to save a few bucks?
