Where does feedlin go for boost gauge?
Old Aug 16, 2004 | 11:19 AM
flusz28's Avatar
i have a s-trim and need to know where to hook up the line so the gauge can read the boost. thanks
Old Aug 16, 2004 | 06:31 PM
2cub49's Avatar
Re: Where does feedlin go for boost gauge?
I hookd mine to a vaccuum port on the manifold on the drivers side.
Just T'd it in and ran rubber vaccuum line to the guage.
Old Aug 17, 2004 | 02:02 AM
slimdawson's Avatar
I ran mine to a port that went to some part of the emissions stuff. It was on the driver's side. Or you could t into any vacuum line as 2cub mentioned.
Old Aug 17, 2004 | 07:41 PM
flusz28's Avatar
all my egr and AIR stuff has been removed from the car. so i guess look somewhere else for a feedline then? can't i just use the line off the bypass valve?
Old Aug 17, 2004 | 10:17 PM
slimdawson's Avatar
All my emissions stuff is gone too. That is why I used the port that originally was used for that.
But yes, you could tee into the hose for the bypass valve.
Old Aug 18, 2004 | 05:42 AM
2cub49's Avatar
Even with the AIR and EGR removed there should still be a port on the intake manifold on the driver's side next to where the brake booster line is.
Old Aug 18, 2004 | 11:08 PM
CoUnTryMuZiCZ28's Avatar
those hoses wont blow off? did you use hose clamps?
Old Aug 19, 2004 | 06:35 AM
2cub49's Avatar
I'm only running 6 psi and my hose fits very snuggly.
I suppose you could put a small clamp on it if you're running a lot of boost just to be sure.
If it blows off you'll know right away as your guage will just say 0.
Formula Steve
Sep 19, 2023 08:31 AM
RUENUF
Mar 13, 2016 03:37 PM
themex2002
Sep 2, 2015 03:47 PM
Aug 7, 2015 01:26 PM
Henson071
Aug 4, 2015 09:32 AM
