Stock LT1 with ATI Procharger P600B and inline fuel pump.
Old Jan 8, 2004 | 03:53 PM
scans's Avatar
Would it be a bad idea to put an ATI Procharger P600B with inline fuel pump on a stock LT1 carrying 106k miles? She is a daily driver with a very light foot. The ATI is for the occasion I drive the car or go to the track.
Old Jan 8, 2004 | 09:10 PM
SC97TA's Avatar
If you do a search I’m sure you will find a ton of threads on this subject.
What is already done to the car?
If you are looking for just a little more power and the car is stock there are a bunch of mods you can do that would be less costly and less risky (heads/cam, headers, catback…) IMHO. You need deep pockets to play with boost at least that’s my experience a motor rebuild seems inevitable. My stock motor lasted 2 years others on this board not so lucky.
What pound pulleys are you thinking of running? I wouldn’t go over 6lbs without an intercooler and 8lbs with.
Tuning plays an extremely important role in how long it will last. If you do go SC then get it tuned on a Dyno with a wideband O2 sensor. With bad tuning it might only last seconds under boost.
Old Jan 8, 2004 | 10:19 PM
mongse_1's Avatar
The best advice I've ever heard on this subject:
"If you can't afford the rebuild, don't run a blower."
It's true, so very true.
Old Jan 8, 2004 | 10:49 PM
scans's Avatar
The car is basically stock ecxept for a cat back. The SC I was looking at does have the intercooler. I am starting to lean more towards engine stuff instead if SC
SpeedJunkee
Jan 27, 2015 10:02 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
cmdeshon
Dec 27, 2014 10:06 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Burn_Out
Aug 18, 2002 08:49 AM
