Stock Heads - Best Compression Ratio for Supercharging
Old Jun 22, 2003 | 07:37 PM
Wild1's Avatar
Doing my calculations, the best I can get with stock heads is about 9.1:1. I was targeting 8.4:1 - 8.8:1. This doesn't seem possible without milling AFR Heads.
What is the best CR with stock heads? Then I suppose I would build the boost to match the best CR... right? 10#s?
Old Jun 22, 2003 | 07:49 PM
rskrause's Avatar
Moderator
Re: Stock Heads - Best Compression Ratio for Supercharging
JE makes some nice "extreme duty inverted dome" pistons. with either a -31 or a -22cc dish. They have worked very well for me. You won't be able to get to the ~8.5:1 range with stock combustion chambers. But as you suggest, with 10psi you should be ok.
Rich Krause
Old Jun 22, 2003 | 10:22 PM
Wild1's Avatar
So, with stock heads, Zero Deck, and 31 cc inverted domes, I should be around 8.8:1?
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Killer94z
Jan 13, 2015 12:06 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Brian-94TA
Jul 31, 2002 02:52 PM
