Stock Heads - Best Compression Ratio for Supercharging
Doing my calculations, the best I can get with stock heads is about 9.1:1. I was targeting 8.4:1 - 8.8:1. This doesn't seem possible without milling AFR Heads.
What is the best CR with stock heads? Then I suppose I would build the boost to match the best CR... right? 10#s?
Re: Stock Heads - Best Compression Ratio for Supercharging
Rich Krause
