So my car is slower now.
Old Mar 30, 2008 | 02:56 PM
  #16
jchevy's Avatar
Originally Posted by reamo04
dyno numbers don't matter, track times do. You ahve something going on pretty bad. I'd say on 5psi you should be trapping 115-120 probably.
Dyno doesnt lie as far as im concerend. There is no bad launches or missed shifts.
Like I said, Im going to do some tuning while its on the dyno too.
Old Mar 30, 2008 | 09:40 PM
  #17
jchevy's Avatar
I know the cam isnt my only problem, but how much is the 224/236 on a 110 lsa hurting me compared to a 224/236 on a 114?
Old Mar 30, 2008 | 11:10 PM
  #18
Kaj's Avatar
Kaj
I'd definetely get the 3:42's back in her...with the power adders you have all you're going to be doing is lots and lots of spinning...I'd perhaps look into getting some better traction and doing some suspension work after you tune it and see if your times hold true to where you're at mod wise. I think w/ what you have you should easily be over 400hp.
Old Mar 30, 2008 | 11:33 PM
  #19
Kredz28's Avatar
The 114 lsa is a much better lsa for boost. 110 is a lot of overlap for a boosted engine. Do you have a boost guage and can verify seeing 5 psi? Just a thought, but that cam may be bleeding off some boost.
Old Mar 31, 2008 | 11:32 AM
  #20
jchevy's Avatar
Yeah, I am seeing 5 psi on my gauge.
I dynoed 380 hp before, so I sure hope I can get more than 400 out of it adding a turbo.
Old Mar 31, 2008 | 04:32 PM
  #21
UR50SLO's Avatar
Do you have any pictures of what was done on the Turbo Conversion?
Yea.. the 4:10's are not right or the cam but even with 5psi it should be scooting.
Somthing is going on.
Does it cut out... miss? anything strange?
Where are your plugs gapped at? any spark blow out?
Don't let the AFR's get any leaner than 12-1AFR Stay in the 11's.
Your MPH is bothering me alot. Dropping out of the teens back to the single 100digits.
MPH is power.
Making over 400hp with a turbo'd V8 should be a No-brainer.
It's in there.. .just somthing missing.
~Scott
Old Mar 31, 2008 | 07:46 PM
  #22
jchevy's Avatar
The car runs great, "feels" stronger than before. Has no hiccups what-so-ever
plugs NGK TR6s and are gapped at .035 If I remeber correctly.
I really couldnt beleive how slow the car ran. I guess Ill see what I can figure out on the dyno.
Old Apr 1, 2008 | 08:14 AM
  #23
UR50SLO's Avatar
Spec's? On Turbo.. piping... ect... BOV stuck open? opening wrong time? Boost controller? Boost leak somewhere?
There's somthing going on.. .just need to narrow down what it is. Your MPH with a turbo should be WAY up not several mph down.
When you find it you'll be laughing... I've seen it several times.. done it a few times my self... Don't worry.. sound like somthing simple just being missed somewhere.
~Scott
Don't worry about ET right now.. just MPH.....
Old Apr 1, 2008 | 03:27 PM
  #24
Rice Killer87's Avatar
I think you'll still be dissapointed after the tune w/ that cam and gears.
Use the turbo to push the car,not the gears.
That 110 LSA cam has too much overlap and is blowing boost out the exhaust = lost HP.
Old Apr 1, 2008 | 06:38 PM
  #25
jchevy's Avatar
The turbo makes 5 psi pretty easily, so I dont think the boost blowing out the exhaust is that big of an issue, there is plenty more air following behind it to fill the cylinder.
What im worried about with the overlap is the backpressure in the exhaust system being greater than the boost pressure, and getting so exhaust back in the cylinder.
The turbo set-up was built by me, They are log style manifolds very similar to the setups realquick sells. Intercooler piping is 3", primarys on the exhaust are 1.75", passenger log is a 2.5" into 2.5" crossover into a 3" main log into the turbo. 3" downpipe in to 3" duals back behind the tranny. Im not seeing super high exhaust manifold temps or anything like that, so i dont think the system has excessive back pressure.
If I am seeing boost on my gauge can I rule out a boost leak in the intake?
my 224/236 has 10* of vavle overlap.
the 224/236 on the 114 that everyone uses has 2* of valve overlap. Could 8* be hurting me that much?
Old Apr 1, 2008 | 06:46 PM
  #26
UR50SLO's Avatar
WE gota see some pic's to help troubleshoot this thing.
You can definatly have a boost leak and not know it on the intake side. Especialy at such low boost levels... 5psi is very low. I know your guy's engines are 11-1comp stock.......
How big is the down pipe? Any other restrictions?
Is the IAT sensor after the intercooler or at the air filter?
Man.. .there's got to be a leak somewhere!!!
You should be making some serious power!
~Scott
HP cams with lca's 110-106 tend to scavenge the cyl and will shove boost out the exhaust valve with out you knowing it.. btw.
AdsoYo
May 2, 2018 03:21 AM
ChrisFrez
Dec 28, 2014 02:25 PM
ChrisFrez
Dec 21, 2014 09:47 PM
cmdeshon
Dec 12, 2014 10:51 PM
USAirman93
Nov 24, 2014 03:37 PM
