Small teaser video
Old Jun 4, 2008 | 11:24 PM
  #16
97s10ondubs's Avatar
Originally Posted by RealQuick
Ricci's DP is on the pass side. He has the A/C delete header version.
yeap, nothing in the way to burn here just bought my 75lb injectors and second pump, let the fun begin
Old Jun 5, 2008 | 07:12 PM
  #17
DirtyDaveW's Avatar
Why do you need an oil pump with a non STS Turbo setup? Is the Turbo beneath/away from the oil pan level you need?
Originally Posted by 97s10ondubs
Thanks man, after a little research i decided to go with this one, http://www.rbracing-rsr.com/oilsystems.htm it's the only pump that uses gears like the stock oil pump instead of a diaphram. Justin i'm running an open downpipe right behind the k-member
Old Jun 5, 2008 | 08:20 PM
  #18
boosted-lt1's Avatar
Hey,
From the video it doesn't seem that loud (sounds real good too). Would you say it's too loud for the street with an open DP?
Thanks,
Scott.
Old Jun 5, 2008 | 08:28 PM
  #19
reamo04's Avatar
Scott, i can answer that
I have open DP on my car too......really, its not that loud after it goes into closed loop and idles normal.
My DP dumps BEFORE the k-member, and its about the same as my true duals w/ spiral flows were.
I wouldnt mind dumping it by the bellhousing, and putting like a bullet or something on it though.
Old Jun 6, 2008 | 08:28 AM
  #20
RealQuick's Avatar
The turbo should have been high enough for gravity drain:
DSC02483.jpg?
Old Jun 6, 2008 | 10:01 AM
  #21
DirtyDaveW's Avatar
Jon, that looks like a good design. The turbo is 'flipped' compared to my design I bought from you. Does this design shown here require the standup radiator or other deletions?
Old Jun 6, 2008 | 09:58 PM
  #22
Besides a/c no, but the fans can be moved to the front of the radiator w/o having to cut the rad support, that what i did and it doesnt get hot at all w/ the pusher fans. Jon it looks like it should drain, but it's really not that big of a difference in the car, it's only a couple inches higher and i didnt want to use 90* fittings b/c i was worried about flow problems, by the time the hose bends it goes under the drain bung and back up to the drain. It's fine for a few minutes of idle, then the smoke show begins and oil leaks out from the exhaust side of the turbo and some of the clamps in the exhaust, barely any in the intake side.
Old Aug 4, 2008 | 09:45 AM
  #23
RealQuick's Avatar
Hey bro, any progress on finalizing the tune? Any dyno or track #'s?
Jon
Old Aug 6, 2008 | 12:06 PM
  #24
haha no, my turbo let go, dont ask me how, it's sitting at precision right now, guess it wasnt the drain causing the smoking
NewsBot
Jun 22, 2015 09:10 AM
NewsBot
May 11, 2015 08:30 AM
NewsBot
Apr 9, 2015 07:10 AM
NewsBot
Mar 19, 2015 02:24 PM
NewsBot
Mar 13, 2015 07:15 AM
