Simple IAT question
Old Apr 7, 2006 | 08:19 AM
CALL911's Avatar
Simple IAT question
At what IAT should you start getting concerned? Cooler IAT's are obviously better, but at what IAT #'s should you start to worry?
Old Apr 7, 2006 | 09:11 AM
DarkHorse's Avatar
Re: Simple IAT question
I'd like to add to this question - how many boosted guys have relocated their IAT sensor and where to?
Old Apr 7, 2006 | 09:28 AM
rskrause's Avatar
Moderator
There is no specific number. As you stated, cooler is better. I see 120-130 degrees at the end of a 1/4m pass using water/methanol injection and no intercooler, 22-23lbs of boost. My buddy with a 5.0 sees 70-80 degrees with ~30psi and an ice water cooled water/air IC, just to give you some numbers.
Rich
Old Apr 7, 2006 | 09:31 AM
DarkHorse's Avatar
Rich is the sensor in the stock location? These can be relocated correct?
Old Apr 7, 2006 | 11:08 AM
rskrause's Avatar
Moderator
The temps I posted are from an accessory IAT placed in the manifold plenum. One could locate the stock IAC if so desired.
Rich
Old Apr 8, 2006 | 11:48 AM
CALL911's Avatar
Thanks! This was pretty much what I was looking for. Just one more question to hich-hike onto the original: At what IAT do you need to start getting concerned about being too hot, or were possible detonation may occur?
Victor Lamb
Aug 26, 2017 02:52 PM
grabbem88
Feb 13, 2015 03:09 PM
Hurin
Dec 13, 2014 07:38 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
