Shortblock FINALLY done, need advice/recommendations...LONG!!!
Old Jan 31, 2004 | 03:33 PM
  #16
rskrause's Avatar
Moderator
Originally posted by 97WS6SCharged
Putting the same amount of air into an engine using less boost will make more power because it will not heat the air as much. When you port the heads, you increase their flow and thus, you will not produce as much boost without changing the pulleys.
Right. More head flow is always a good thing, provided you don't screw up the port velocity to the point where low speed operation is adversely affected. The nice thing about a blower is that you don't need huge port volumes to get big hp. But the general principles still apply and if you want even more power you will need better heads.
Rich Krause
Old Jan 31, 2004 | 09:01 PM
  #17
97WS6SCharged's Avatar
See, I can be taught.
Old Jan 31, 2004 | 09:32 PM
  #18
OBE1 95Z28's Avatar
What are the pros/cons with Brian going with bigger AFR heads?
Old Feb 1, 2004 | 01:01 AM
  #19
Pro... They work really well when they are cleaned up. Also, you can order different sized chambers to help get the compression down.
Con... They ain't cheap.
Old Feb 1, 2004 | 06:49 AM
  #20
rskrause's Avatar
Moderator
That's about the size if it!
Rich Krause
Old Feb 2, 2004 | 08:29 AM
  #21
BlownF1's Avatar
Originally posted by blown383
Brian when you step up to the AFRs are you selling your stockers? If so Imight be interested.
-B
Hey B - I'll likely have 2 sets of stockers available. The first will be straight off my car when we yank the motor, and the second set is ready to go with all new hardware, but were NOT ported (don't ask!) due to a miscommunication it seems. I won't be using either set. Should be available in the next month or so...
Old Feb 2, 2004 | 08:39 AM
  #22
BlownF1's Avatar
Originally posted by rskrause
You would be a good candidate for "my" small blower cam. CC XE lobes #3190/3192
Thanks Rich! I'm willing to give that a shot...what do the two numbers above refer too? The part number? I looked at a few sites, but couldn't readily find either one.
You can't calculate the CR without knowing the combustion chamber volume of the heads.
Right, I meant with stock heads to start with. I was afraid that if I didn't know the correct compression ratio with stock heads, I'd lower it way too much with bigger heads. I'm definitely wanting to buy the AFR's, just not sure which one to get at this point.
Old Feb 2, 2004 | 08:46 AM
  #23
BlownF1's Avatar
Originally posted by Injuneer
The thing that caught my eye is the "2-bolt" mains with a blower and nitrous? Seems counter-productive.
Good eye for the details Fred! I put that in intentionally to see what kind of feedback I'd get. I tried several times, but couldn't get the builder to even consider taking my money to do the 4-bolt conversion, he's adamant that it's unnecessary. So I guess we'll see...
Old Feb 2, 2004 | 08:55 AM
  #24
BlownF1's Avatar
Originally posted by tanker
Congradulations on coming to the end. I am just starting my new blower shortblock rebuilt, shopping for parts. I am hoping it won't take methree years , but thats all money dependent. I was wondering how much the shortblock rebuilt cost you with parts? Also why did you decide to go two bolt, not four? I always thought that for a blower ported heads don't help too much since you are pushing lot's of air in??
Thanks, I definitely wish you better luck! Best advice I can offer is, DON'T deal with family and friends no matter how much savings you're promised! In this particular industry you need to be able to chew some a** once in awhile, and that's not easy to do with family/friends. In my case, the parts were paid for the first 2 weeks of the project...the rest of the time was one BS excuse after another. DON'T deal with family and friends! My advice to you is babysit the project EVERY step of the way and don't hesistate to yank all your stuff back and go elsewhere at the first sign of trouble! DON'T deal with family and friends! I don't know on the final cost yet, but figure to spend around 6K if you're doing the install yourself, others can probably give you a better idea.
And remember, DON'T deal with family and friends!
Old Feb 2, 2004 | 01:18 PM
  #25
blown383's Avatar
Thanks Brian let me know.
-B
Old Feb 2, 2004 | 05:49 PM
  #26
TimbrSS's Avatar
Without know the exact specs of your motor to calculate the actual compression ratio, you can use the numbers listed to get you close. If you have stock heads ~58cc = ~9.2:1. Should be good for around 12# on pump gas. Probably around 500rwhp with unported heads, closer to 600 with a set of well ported stockers.
If you don't have the big $ for AFR's, you should be able to pick up a set of ported stockers for around $1000-1500 or so that will get you closer to your goals.
If you got the $, you can get the AFR's in any size you want from 76cc to 54cc.
Old Feb 3, 2004 | 08:08 PM
  #27
menlatin's Avatar
I dont think you're going to get that 600rwhp for too long with the 2 bolt main. I mean you NEED 4 bolt mains if you want that power and any kind of longevity. And better yet, if you get the splayed 4 bolt, they are probably going to get billet caps, and thats even better than a stock 4 bolt.
magman
Apr 15, 2016 03:08 AM
PopoFormula
Oct 12, 2015 04:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Ks0209
Oct 1, 2015 07:32 AM
kandied91z
Sep 30, 2015 11:43 PM
