Setting Compression ratio, I'm ordering parts tomarrow
I'm planning on running a T-76 turbo at about 15-20 psi on pump gas, 92 octane. I was going to put my compression ratio at around 8.8:1 Do you guys think this is wise? Can I get away with more compression? I really don't want to blow up this motor and will dyno tune it safely.
I'm looking for a reality check here. I'd love to hear some suggestions or what CR and boost level you guys are running on pump gas. I'm ordering the pistons tomarrow. Thanks in advance.
Re: Setting Compression ratio, I'm ordering parts tomarrow
i spoke with c motorsports about this, and after talking to them i have decided to go with trick flow heads to get compression down to 8.4:1 ...im gonna be running two master power t-70's ...so were probably talking right about the same boost/power levels...they basically said if your running pump gas, the lower the better...mine will be a street car with only occasional track use...so im going as low as possible
I called a few companies today and they all suggested 8.5 - 9.0 :1, leaning towards the 9.0 side to get better street responce.
Originally Posted by mn_vette
I called a few companies today and they all suggested 8.5 - 9.0 :1, leaning towards the 9.0 side to get better street response.
Most of the time, you cannot tune 20psi on pump gas even with a FMIC on 92 pump gas. Unless you have the timing cut back so much that you could make the same power at like 25 degrees and 14 psi. (those are just general numbers).
I would go 8.25:1 and look into reverse dome pistons.
Originally Posted by Pro Stock John
Hmmm. Think about your statement. What do you mean? have you felt 600rwhp at 5000 rpms? How about 700rwhp at 5000rpms?
Rich
Well, I went to a 34cc dish piston. That should get me right around 8.6:1 that should get me pretty good up til around 15psi on pump gas. If I need more boost then I guess I'm gonna have to go with some octane booster or race fuel. 15psi on the street should be plenty though, don't you think? If......um, when....I feel I need more I'll figure it out from there. Maybe a set of afr's will be in order then.
-34cc? thats a big dish...why dont you just go with -24 and some trick flow heads or AFR's? trick flows price is very reasonable...i just picked up an unassembled set for $700 ...with the -24cc dish, it puts it at 8.4:1 ...-34cc dish is an option, just expensive for custom pistons
Actually it's going to cost me about the same for custom pistons. Its nice when you know people that know people
And my chambers just got cc'd they are 60cc and flow about 250 on the intake side. So I could dump another grand into Tricflow heads and end up the same place that I'm at now which doesn't make any sense to me. Besides the Trickflow heads only have a 62cc chamber(some ads say 64
) so I'd still need a really big dished piston. I could go with AFR's but those things will set me back like $3k with intake and everything, so that's out of the question.
Sounds like a good move. Folks generally push for too much engine compression.
rskrause, 7.8:1 no kidding. Meaney is right around there.
I am 8:1 on paper, max of 8.2:1 I think.
